This combo will be going on my daily driven 91 lx 5-speed...The motor has 100K on it...What do you guys think? I am want to go with stock castings in this particular combo for personal reasons... Need some suggestions if extrude honing the upper intake would be beneficial with the flow numbers of the heads...Reason for asking is that it seems as though intakes usually flow less than heads...Not sure why that is besides maybe velocity issues but would this be considered a bottle neck?
I also need a suggestion as in regards to a cam...Thinking of going with FTI grind but not sure how the cam will respond to the heads and vice versa...
Also what kind of headers would give me the most from this particular set up...shorties or long tubes? I know that long tubes make more but not sure if that would be too much exhaust for those heads...any input would be appreciated...
Any ideas about the RWHP and RWTQ with this setup?
P.S. I have also noticed that the runners on the intake are larger than the runners on the heads by a bit...would this cause a problem in terms of turbulance since the intake is slightly larger than the heads?
-Greg
any ways here is the combo thus far...
-Systemax 1 lower intake
Systemax 1 lower flow number results: .
1 220.3
2 213.8
3 227.5
4 212.4
5 225.4
6 208.4
7 225.7
8 220.1
-Stock upper vs Extrude Honed upper flow number results:
1 193.6 210.2
2 190.2 208.7
3 182.8 205.1
4 183.0 197.5
5 182.5 195.7
6 186.3 205.6
7 188.9 205.4
8 189.4 205.8
-Powerheads CNC ported E7TE heads flow numbers:
INTAKE:
.100" .200" .300" .350" .400" .450" .500"
63.5 124.0 189.5 202.9 213.0 216.5 217.0
EXHAUST:
62.5 109.0 150.5 162.0 169.3 172.4 174.0
Rest of the setup:
Pro-M 77
65mm TB
3.73
full exhaust
1.6 roller rockers
pullies
crane HI-6
-Greg
1 220.3
2 213.8
3 227.5
4 212.4
5 225.4
6 208.4
7 225.7
8 220.1
1 193.6 210.2
2 190.2 208.7
3 182.8 205.1
4 183.0 197.5
5 182.5 195.7
6 186.3 205.6
7 188.9 205.4
8 189.4 205.8
INTAKE:
EXHAUST:
Rest of the setup:
Pro-M 77
65mm TB
3.73
full exhaust
1.6 roller rockers
pullies
crane HI-6
