Need.................................Look!
  • Thread starter Thread starter 66mustanger
  • Start date Start date May 23, 2004
66mustanger
25
mason,ohio
May 23, 2004
  • May 23, 2004
I need help with my heater core! Can anyone give a complete breakdown on a step by step instructions on how to remove it? Or just give a link to some instructions! I greatly appreciate it! My Haynes Book sucks on alot of detail, or lack of there of! Thanks,
God Bless America!
Edbert
3,548
32
109
Austin TX
May 23, 2004
  • May 23, 2004
You, and everyone here, need to have the Ford Shop manual. It is about two inches thick and, for my year, a light blue color. You can buy them from any of the parts houses.
Basically you just take out the heater box. Open the heater box while it is out of the car. Then remove the heater core, it is very much like a small radiator. Put in all new foam and rubber seals, then re-install the box.
Swede958
712
Austin, TX
May 23, 2004
  • May 23, 2004
Ok- write up for doing the heater core on my '70 sportsroof.
Get someone else to do it (if not, go to next step)
If too stubourn- unhook lines going to firewall (if A/C- unhook those too).
On my car I pretty much had to pull the entire lower dash off, along with the upper dash, glovebox door, console, etc to get the damn thing out.
Take lots of pictures, invest in the manual, and grab a 12-pack for the celebration cause once you've finished you do have reason to celebrate.
Also- good idea to get heater core and/or evaporator pressure tested while they are out.
THe Swede
351w_swap
263
  • May 23, 2004
I agree with the swede, although probably not as tough as his 70 sportsroof. You may need to drain some antifreeze from the radiator, and also be sure to have something to plug the hoses with. I made a mess all over the carpet, even after the radiator was completly empty for removal.
M
  • mnky99
  • Sep 5, 2025
mnky99
M
Timing chain, guides and tensioner installation (Possible orientation in Intake Stroke)
  • StallionMax
  • Sep 21, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Sep 24, 2025
StallionMax
D
Need help for my PCM Mach1
  • Danaololo
  • Jul 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Jul 30, 2025
Danaololo
D
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
J
Car Diagnosis
  • j.2016
  • Aug 31, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 31, 2025
