need lower intake help
JenkinsBS
1,001
Washington
Hey guys, im in a jam right now, i need to take my lower intake off to remove the heads on my 86gt, however the shop that put my motor together REALLY used alot of RTV to hold it on there.
Ive removed all the bolts holding the intake down, and im yanking, prying, and pulling but, the intake wont budge...
Anyone ever have a similar problem? and if so, howd you get it off?
hopefully that will work, im gonna give it a try now
before, i was standing INSIDE the engine bay yanking UP on the thermostat housing, and the engine was actually tilting back everytime i lifted... damn strong RTV...
Sounds like they probably used Right Stuff or something like that. Try the pry bar like Tony said.
Good luck!
Jeff
good lord, even pry bars arent working!!
i took the T-stat housing off, and again, standing inside the engine bay, lifted up on the pry bar till the engine started lifting up!
I cant imagine what this guy used to seal the intake to the engine!
Any more ideas?
I guess you've already tried a pry bar between the head and lower intake. There are little spots on the lower intake where you can put the pry bar and pry. And do make sure all of the bolts are out...there are 12 if I remember correctly.
