  • SN95 4.6L Mustang Tech
Need more HELP!!!
  • Thread starter Thread starter edothekid
  • Start date Start date Mar 3, 2004
E
edothekid
165
California
Mar 3, 2004
  • Mar 3, 2004
What's up guys,
Well thanks to everybody for all the advise on my previous thread- The stang was overheating. Turns out it was a clogged radiator, out of the 20+ lines, only 5 were flowing freely. The rest were completely shut.
Well, I have a new problem.
My car is having some kind of power surge. It drives fine, but once in a while while I am at idle or low RPM's the radio will shut off and turn back on. At first I thought it was a loose radio wire, but now what it does is turn off the radio, the blinker will go crazy, the battery guage will go crazy and the RPM's will shoot up a little and then back down. Almost like a short, but throghout the whole power system.
What should I check?
It's very weird becuase it's not like a short on the dash, but on the whole car.
Please help!!!
P.S. I recently removed my diablo chip and reset the computer.
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Mar 3, 2004
  • Mar 3, 2004
i would have the charging system checked first , incase its a short in the alternator of voltage regulator , which could also cause and engine surge problem , then go from there , make sure if its only doing this from time to time to have the test done while its screwing up .
Jinx
I like cats, cats like me. Cats and I fully agree.
20+ Year Stangneter
Oct 2, 2003
12,166
4,237
223
Cat Country
Mar 3, 2004
  • Mar 3, 2004
Sometimes it's the simple things. Check to make sure you are getting good contact at your battery terminals and make sure no corrosion has traveled down the main power wire (happend to Moms '95 GT).
Good Luck and glad to hear your radiator is now unconstipated and flowing free again.
CTGrey02
1,403
Bristol, CT
Mar 3, 2004
  • Mar 3, 2004
Check to make sure your battery and alternator are both working properly. As stated, check the connections on the battery. Would suck to buy a 50 dollar battery only to find that you had a loose ground.
E
edothekid
165
California
Mar 3, 2004
  • Mar 3, 2004
Thanks, I'll check the cables and make sure my charging system is working.
No to think of it, I did notice some corrosion on the positive cable, maybe that could be the problem.
Thanks guys!
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
M
Need help!
  • Masonevans726
  • Dec 17, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 17, 2025
Masonevans726
M
T
Progress Thread 2002 Mustang 3.8L CV
  • TheIncompetentMechanic
  • May 26, 2026
1996 - 2004 SN95 Mustang -General/Talk- Jun 1, 2026
T
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
Need help asap
  • shaggyman65
  • Dec 24, 2025
1996 - 2004 SN95 Mustang -General/Talk- Dec 24, 2025
shaggyman65
