Need new brakes! Help with what I need??
I just bought this Mustang and it's in severe need of a performance break system. They get hot pretty quick and don't work worth a damn. It's frightening at times.
I've been looking at Baer, however they have a couple of different models to choose from and I'm pretty much lost.
I'm pushing 475 rwhp, with 17 x 9 Bullit wheels, with a 5 stud conversion. What should I look for in break systems? I only want to go with the fronts at this point. Is there a specific brand/model, rotor size, caliper type, etc, etc... that I should be using?? I was also told about Bremco and willwood brands.
Thanks!
<http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=4555268578>
I'm guessing the current 5-lug setup is Lincoln/SVO rotors? Your centercaps probably don't clear on the front unless you did some machining to the hub. Best bet is gonna be to get SN95 spindles (go '94-'95 since you have 17x9's) and '94-'04 Cobra rotors and calipers. You'll also need a bigger master cylinder ('94-'95 GT, '94-'98 V6), 3-2 port conversion kit, and adjustable proportioning valve. The link posted above has a ton of good info, and you need to read it, but this'll get you started.
Brian
