  • 1994 - 1995 Specific Tech
need new trans
  • Thread starter Thread starter cejus13
  • Start date Start date Nov 16, 2005
C
cejus13
33
  • Nov 16, 2005
5th and reverse are goin out.crapola where can i get a cheap reman or the parts to rebuild mine (95 5.0 5 speed) and good info on how to do it. i think the drive shaft is bent from hitting the tunnel and is where all the problems are coming from. so im taking out the 2" lowering springs and getting a 1" drop and a new alum ds, im getting a bad vibration when i get off the gas and i am still in gear. i wanted a alum ds anyway but i didnt want to mess with the trans so i hope this is the fix or this mf will be for sale!
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Nov 16, 2005
  • Nov 16, 2005
is it hanlonmotorsports that has the video? I can't remember for sure. How are 5th and reverse going out? What is it doing? I have heard of gears "going out" in autos...but not in sticks.
And i seriously doubt that the driveshaft is bent....
Something else must be wrong in there.
94-302-vert
1,947
NE CT
Nov 16, 2005
  • Nov 16, 2005
If the d/s is bent it will not matter if you are in gear or not. The vibration will jsut get worse with speed (mainly) then load. So I too doubt the d/s is bent.
As for the T-5 I know mine too is getting close to rebuild time and I am in the air between straight rebuild by me, rebuild by someone else (time is at a premium) and upgrading inly when i need to...
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Nov 16, 2005
  • Nov 16, 2005
I dont know for u guys but for me, when i got estimate of just under $500 to rebuild my t-5....i decided to put that money towards the tremec since i KNEW it wasnt going to last anyway. Its a 1/3 of the cost...and i would be mad if in year the tranny did break.
I cant imagine what would actually cause the DS to bend. Maybe be out of balance or something. Do u have gears?
loudpedal99
160
ND
Nov 16, 2005
  • Nov 16, 2005
Ford doesn't exactly have the greatest rep for balanced driveshafts; the tbird and large truck guys have a ton of problems with them. Gears will amplify this problem. If the shaft isn't balanced well it'd feel like it was shaped like a banana at high speed.
The vibration could also be caused by a bad u-joint.
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Nov 16, 2005
  • Nov 16, 2005
U can say that again...shortly after getting gears i got a new FRPP DS.
C
cejus13
33
  • Nov 16, 2005
u joints are new. when i try to shift into 5th it grinds and i have to try at least twice to shift in to 5th and if i get it in gear and let off the gas it pops out of gear. and sometimes it goes in and pops out of gear a couple of times but the shifter doesnt move. could the vibe be from a bad bearing, chipped tooth on a gear or a bent shaft ( i feel it the the most when i down shift into 3rd and im not on the gas, then i speed up an it stops?) reverse just grinds unless i sit still for a few seconds after i stop (syncro's?)
S351R"Animal"
20+ Year Stangneter
Dec 3, 2002
708
Manhattan, KS
Nov 16, 2005
  • Nov 16, 2005
Chances are in both 5th and reverse that the synchros are shot. The driveshaft will warp if slammed into the tunnel. I did this once when I twisted an axle tube and messed up the whole rear suspension.
SeventyMach1
Keep it lubed .... keep it straight .... and keep
Mar 30, 2005
1,940
North Carolina
Nov 16, 2005
  • Nov 16, 2005
If you're looking for a good reman .... I got mine from Phoenix Hard Parts for $695. It has held up great. But I now wish I had just done the G-Force upgrade ..... as I will soon be adding lots of power. Then bye bye T-5 ....
Blackened302
1,439
South TX
Nov 17, 2005
#10
  • Nov 17, 2005
  • #10
needing a new tranny diserves lots of amnit: 's
C
cejus13
33
#11
  • Nov 19, 2005
  • #11
I'm just going to rebuild it, I have the cash for a new one but I want a new hood and paint. Im going to get a steel bearing retainer, a bearing and syncro kit, but what other parts wear out (besides gears) that I might need cuz i dont want to have it torn apart and have to wait a week for something that i didnt get to come in the mail.
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Nov 19, 2005
#12
  • Nov 19, 2005
  • #12
astro performance also sells kits
C
C4 trans help needed
  • CPH89LX
  • Apr 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 28, 2026
CPH89LX
C
Engine New factory manifold no start
  • Fishnchips
  • Oct 15, 2026
1994 - 1995 Specific Tech Oct 22, 2026
DadLife0724
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
3.08 gears with a manual trans
  • limp
  • Aug 27, 2026
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 14, 2026
Qtrhrse23
