Need quick help used wrong pattern lower intake
tbud
Yesterday when torquing down the a cobra lower on GT40p heads. I used a center out torque patten to 23 lbs of torque. I now know this is the wrong pattern. Should I redo it? Will I need new gaskets or can I just loosen up the bolts and retorque with the proper sequence. Car still has upper off and hasnt run.
Thanks
tuff5liter
center out is the right pattern i just went thru this crap on my car all the torque sequences you find on the net is wrong....i went thru like 5 sets of gaskets before i figured it out
it should be done in 3 steps
8ft lbs
16ft lbs
25ft lbs.
9 5 1 3 7 11
----towards the radiator--->
12 6 4 2 8 10
tbud
I did it in three steps but the pattern you described is kind of like a star pattern. I torqued the intake just like the head bolts pattern
1173159
12842610
I hope this makes sense.
Maryland Stang
1,656
28
39
Greenville, NC
According to my Ford factory service manual the sequence is as follows.
There are 6 bolts on each side. Looking at the engine from the front of the car the number 1 bolt will be at the front and left side of the engine. The number 7 bolt will be at the front and right side of the engine. The left side has bolts 1 through 6 and the right side has bolts 7 through 12.
The sequence is:
2-11-5-8-1-7-6-12-3-10-4-9
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
Center out is incorrect for the lower intake. Maryland Stang has listed the proper pattern.
Simply loosen them a bit and retorque. I'd take it up in 2 or 3 steps - if things are true and square, 18-20 ft-lbs is plenty.
Michael Yount
Mustang Master
Apr 10, 2002
9,039
Charlotte, NC
The sequence you need is listed by Maryland Stang above - here's another similar version of it --- as if you're standing in front of the car looking under the hood; tighten them in the order of the numbers:
5--6
3--2
11--10
9--12
1--4
7--8
You'll see the middle 4 bolts get tightened in an X-pattern LAST; intermediate 4 bolts get tightened in an X-pattern FIRST; and the 4 corners are tightened one end at a time IN BETWEEN the intermediate bolts and the middle bolts.
Use a torque wrench so you don't OVERTIGHTEN them - the castings are fragile. I'd take it to 10 ft-lbs in order; then 15; then a final pass to 18-20.
