Need Some Help!!!! Clutch?
  • Thread starter Thread starter 94cobraslow
  • Start date Start date Dec 14, 2015
First Prev 2 of 2
skiwesser11
5 Year Member
Jun 19, 2012
315
33
59
Rock Hill, South Carolina
Dec 27, 2015
#21
  • Dec 27, 2015
  • #21
Were dowels replaced in flywheel?
I've heard if they're not located correctly you'll have vibration. Although I suppose you need them to locate PP. just a thought
94cobraslow
67
tx
Jan 14, 2016
#22
  • Jan 14, 2016
  • #22
sry guy been busy well had the drive shaft rebuild and balanced and put new motor mounts and nothing changed!! i called lmr and they told me the clutch will chatter but after a 1000 mile it should lessen that doesn't sound right to me ! but if the clutch is disengage i shouldnt feel anything when revving it up right? but they also told me i cant warranty it out tale i have it checked by a trans shop and they say it bad!!!!
94cobraslow
67
tx
Jan 14, 2016
#23
  • Jan 14, 2016
  • #23
how bad of a clutch chatter shacks ur a** when rev a car an going down the road?
94cobraslow
67
tx
Jan 14, 2016
#24
  • Jan 14, 2016
  • #24
well in going to replace the new billit flywheel what better for drag
racing steel or aluminum?
B.erazo712
235
46
48
Jan 14, 2016
#25
  • Jan 14, 2016
  • #25
Just a question... What do you got now? Personally i'd go with a steel flywheel.
A5literMan
At least it is lumpy...
5 Year Member
Jul 30, 2011
4,674
2,343
194
Illinois
Jan 15, 2016
#26
  • Jan 15, 2016
  • #26
Don't use an aluminum. You need the extra weight of a steel flywheel.
OneWheelPeel
250
42
48
North Carolina
Jan 15, 2016
#27
  • Jan 15, 2016
  • #27
I don't know how bad your car is vibrating but I've heard going to a poly trans mount could make you feel more vibrations. When I switched to solid motor mounts I noticed a lot more rattles in the car. It may not be your problem but its just a thought.
94cobraslow
67
tx
Jan 16, 2016
#28
  • Jan 16, 2016
  • #28
For all the ques, ford racing billit steel flywheel, and the vibration as bad or worse then a u joint vibration but it doesn't matter if im in neutral in gear ,driving ,clutch disengage ,engaged every gear the vibration come in at the same rpm and get worse as rpm increase and balancer looks good and no vibration before clutch and flywheel install
B.erazo712
235
46
48
Jan 16, 2016
#29
  • Jan 16, 2016
  • #29
Just a run through. You have a pilot bearing, your clutch, bell housing, tranny, and crossmember torqued down to specs? A good transmission mount tightened down. Driveshaft torqued to specs. If you didn't have problems before you did your clutch job, it must be something you did. I would double check everything.
94cobraslow
67
tx
Jan 16, 2016
#30
  • Jan 16, 2016
  • #30
Been there Done that 2 times
First Prev 2 of 2
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Car shakes when taking off help???
  • STANKYstangs
  • May 10, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 27, 2026
LILCBRA
F
Please help 00 mustang 3.8 v6 T5 manual transmission Tail housing cracking
  • FF-DC00
  • Jan 2, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Jan 2, 2025
General karthief
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
