Need Some Help!!!! Clutch?
sry guy been busy well had the drive shaft rebuild and balanced and put new motor mounts and nothing changed!! i called lmr and they told me the clutch will chatter but after a 1000 mile it should lessen that doesn't sound right to me ! but if the clutch is disengage i shouldnt feel anything when revving it up right? but they also told me i cant warranty it out tale i have it checked by a trans shop and they say it bad!!!!
I don't know how bad your car is vibrating but I've heard going to a poly trans mount could make you feel more vibrations. When I switched to solid motor mounts I noticed a lot more rattles in the car. It may not be your problem but its just a thought.
For all the ques, ford racing billit steel flywheel, and the vibration as bad or worse then a u joint vibration but it doesn't matter if im in neutral in gear ,driving ,clutch disengage ,engaged every gear the vibration come in at the same rpm and get worse as rpm increase and balancer looks good and no vibration before clutch and flywheel install
Just a run through. You have a pilot bearing, your clutch, bell housing, tranny, and crossmember torqued down to specs? A good transmission mount tightened down. Driveshaft torqued to specs. If you didn't have problems before you did your clutch job, it must be something you did. I would double check everything.
