These stud mounted tfs 1.6 rockers are kicking my ass.
I've adjusted them several times now with no success.
I just fixed an oil leak on my lower intake and decided to attempt rockers yet again. This time they are louder than last time. They are really loud that I don't want to drive the car. Anyone that has done this several times and went through what I am going through please help.
I tried following the procedure as best as I could. This is what I did:
Found TDC on #1 cylinder. I did this by watching the #1 cylinder intake and exhaust rockers and rotating the crank (clockwise). When it came to 0 (TDC) on the balancer I adjusted the rockers. Once I felt decent resistance on the pushrod, I did 3/4 turn of the adjusting nut and locked the allen nut. Turned the crank 1/4 turn and proceeded to cylinder 3 (i think). I followed the firing order.
My dipstick's location has kinda changed since the new TW heads are a bit taller. I think there is enough oil in the engine. Should I try add a quart? What happens if there is too much oil?
What do you think I am doing wrong? Could it be me finding zero lash? I just want them to be decently quiet.
Thanks guys.
Thanks guys.
