Need some help trouble shooting
Big Kev
I have an 87 GT with a few mods. Converted to Mass Air. I'ts started running like crap, it will idle for a few minutes then it will start surging and finally shut off. It loses power in the mid and upper rpm range and it runs rich while I'm trying to test it. I have two new O2 sensors a new TFI module and a new Idle Air Control Sensor. It maintains 35psi fuel pressure the air/fuel gauge stays on the rich side now all the time. Also has new distrubitor cap and rotor button. It has a C&L 73mm mass air.
Checked the codes and It keeps coming up KOEO 21 81 82 95 15 and Engine on 98 and 66
21 is ECT
81 and 82 are the smog system
95 Fuel pump: open, bad ground or always on - Power / Fuel Pump Circuits
15 No Keep Alive Memory power to PCM pin 1 or bad PCM (Memory Test Failure)
98 Did not pass KOEO yet (Get 11 in KOEO first)
66 Vane Air Flow (VAF) or Mass Air Flow (MAF) signal low - VAF MAF
Any suggestions on where to go from here, I'm an old school drag racer and used to dealing with carb engines. I need a little help with the electronics on this car. LOL
Was the engine up to temp when you pulled codes? An ECT code can generate if it wasn't.
95 can occur on MAF retrofits as I recall. Could that apply to you?
Do you run a chip? I'd be concerned if you're losing KAM power. If there's some adaptation occuring (to deal with your combo), it's all lost after each shut down.
Lastly, the MAF code could be the most important. If you're able to try a different (OEM. Totally OEM) meter, I would.
Good luck.
I would think since the MAF is larger than stock and set up for 24lb injectors that it might give a code.
I pulled the connector from the MAF and it still runs like crap, so I kind of ruled out the MAF giving me any problems. (But I'm an amateur with Fuel Injection) and I don't know if it would make a difference.
I do have a chip but I pulled it before all the testing. Timing is 12 degrees base at idle, I cant figure out what is making it surge and die when idling and why it loses power in the mid to upper RPM range.
Could my ECM be fried since I'm getting code 15?
A sig is a nice thing to post up. I didnt know what to assume about your combo before (like you having 24's or a chip).
You're right - your meter is accomodating/crutching for the 24's as far as the EEC is concerned. You still have to wonder if something is wrong with the meter itself however. I'd expect a noticable difference if a healthy meter is disconnected.
When you said (paraphrased) timing is set at 12, based on idle (that's carb talk/thinking there), was your SPOUT connector pulled when the timing was set? I had to ask.
Code 15 can be generated by a chip. Once codes are cleared and the car started and codes checked again, it should go away. If not, check ECM Pin 1 for constant power.
Sorry about that, I should have listed all the mods. I'm frustrated with this thing because I'm having to fix all the Jerry Rigging from the previous owner.
I thought about the code 15 and I might be getting that from disconnecting the battery and clearing the codes when I change a different part.
Timing was set with "spout connector" removed.
