I just put a 2002 PI engine in my 97 GT.
Before Idropped it in, put new head and intake gaskets etc......I did not replace 1 intake gasket because Mustangs unlimited forgot to send me two...
The problems I having is....its fires right up idles just fine but when I tap on the throttle it bogs way down, similar to a vacuum leak. Its hard to tell if it is a vacuum leak because of the CAI setup, and the sucking of air. I have tried using carb cleaner and hitting up the intake/throttle body gaskets...but I did not notice a change in idle. I did not however change the plenum or tb gasket when did I the swap. Any ideas.....
Thanks
Thanks
