Need some help with a posi !!
1bad67sbf
674
N. VA
im still working on getting some issues fixed with my car but in some "testing" lol, i had some one tire fire going on. it would start with posi but when i grab the brake it would slip to one.
here is the issue, do i rebuild or replace?
i have to go into it to do the five lug swap that i already have setting around so, what would you do?
if you say replace is the true trac the best?
Detroit Truetrac Differentials
The 1650 HP orange/black car had an 8.8. Granted, it was far from stock, axle tubes were welded and braced, tied into a diff cover that bridged the two axle braces. Billet caps, Pro gears, 35 spline axles, w/ a full spool.
Blahdy-blah-blah.
It was a turbo car w/ an auto on drag radials, so it wasn't as hard as it could've been on the rear, and I may have just been lucky, but, ........:shrug:
I wouldn't worry about hurting the one you have. I'd do like Allen suggested and freshen up the one you have.
Unless you plan on building something w/.......... a little more power :D
