Need some pro incite.
  • Thread starter Thread starter Dallas1993Vert
  • Start date Start date May 20, 2010
D
Dallas1993Vert
  • May 20, 2010
OK I am asking the Pro's once again.. this is what I have done to my car, it is a 1993 Vert 5.0 (well was )
The questions to keep in mind:
1. Do I need a better intake? if so which one?
2. Have a 70 MM Mass Air. Do I need to use a 75?
3. What stall convertor do I need?
4. What horsepower can I expect?
5. What 1/4 time can I expect (I have 25+ track runs)?
Ok list of Mods:
5.0 Bored .30 over
Flattop Pistons, forged rods
Newly turned Crank
fresh rebuild of complete motor
fun stuff:
ARP 165 202 Ported and Polished heads
1.6 Ford Racing Roller Rockers
GT-40 Lower Ported and Polished and gasket matched to ARP Gaskets
GT-40 Upper Ported as good as they can
30 Lb Injectors
190 LPH Fuel Pump
70 MM Throttle Body
75 MM Mass Air Meter
X-cam (stock Duration)
Off Road X-Pipe
Headers
New Mufflers - Pypes (Dont know model, they were on the car)
Freshly Rebuild AOD trans with shiftkit and 3000 stall.
Thanks for any info or help you can provide..
notchback
1,950
St Clair Shores MI
May 20, 2010
  • May 20, 2010
no a 70mm is fine. meter size is GROSSLY overrated. check out livernois motorsports mustang. it runs 7's and i think it has a 105mm (apx 1100 hp)
no, the gt40 is great, ported it will support 400 hp (do you have a tubular, cobra, or explorer?)
i would go 4k on stall, absolute min of 3000
hp estimate is about 300
1/4 mile ET should be about 12.60-12.80 at about 106 assuming you can pull a 1.8 or better 60 foot
ahhh.. i just read "'93 vert" and 3000 stall
what converter do u have ???? and i change my mind.....maybe closer to like 12.70-12.90 at 105, thats assuming you have a stallion or lentech... NOT a TCI
  • Locked
Engine Might have to get a Dart block but don't want to and if I do, then 363 instead of 331. Thoughts on what I've already bought so far.......
  • from6to8
  • Jul 8, 2025
Fox 5.0 Mustang Tech Jul 8, 2025
H
turbo advice
  • hawkinsdrag
  • May 5, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2025
hoopty5.0
F
Electrical Foxbody wiring harness 2.3 to v8 swap
  • Foxbodyjake
  • Mar 23, 2026
Kleinjj27
K
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jun 20, 2026
gray owl
G
Fox 329 HP low for a stroker?
  • Andresquintana.mma
  • Apr 15, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 19, 2025
Jarhead67
J
