need some susp. help
  • Thread starter Thread starter strokedandblown
  • Start date Start date Sep 27, 2005
strokedandblown
Banned
May 3, 2005
555
USA
Sep 27, 2005
  • Sep 27, 2005
well seems like im having susp. problems like everyone else, mine are sorta self induced. I just got my torque boxes reinforced and ive relocated the battery to the trunk as well as my ummm ...... 160lb system give or take a couple. Now my axel hits the pinion snubber under load and makes a vibration which well sucks bad.
heres my susp.
Drivetrain:
Star Spec Stage III clutch
SVO Aluminum Clutch Cable & Quadrant
Tremec TKO 600
Aluminum Driveshaft
strange spool 31 spline
Suspension:
SVO Subframe connectors
KYB Shocks/Struts
Steeda Caster/Camber Plates
Steeda Sport lowering springs
Steeda Tubular Front Stabilizer Bar
Steeda Heavy Duty Rear Stabilizer Bar
Steeda Adjustable Rear Stabilizer Bar (for sale)
Steeda Rear Heavy Duty Upper Control Arm
Steeda Rear Aluminum Lower Control Arm
Slot-Car Anti-Squat Brackets
Aluminum Offset Steering Rack Bushings
I was thinking maybe trying to put the stock springs back in this one really baffels me.
thanks
(im not taking the sys. out )
STANGateURlilSS
716
USA & SANDBOX
Sep 27, 2005
  • Sep 27, 2005
how much clearance do you have between the pinion snubber when the car is sitting on the ground??
strokedandblown
Banned
May 3, 2005
555
USA
Sep 28, 2005
  • Sep 28, 2005
about an inch, and its the little snubber not the factory one. this is rally pissing me off. I hope someone can figure this out, i have a feeling if i put the stock springs back in the car wont sit right...
strokedandblown
Banned
May 3, 2005
555
USA
Sep 28, 2005
  • Sep 28, 2005
rEally dumb question but im gonna ask
can i make my rear end rigid or is that just crazy talk??
srothfuss
Last night I stabbed the same guy 7 times in a row
Oct 17, 2004
1,796
Woodward Ave.
Sep 28, 2005
  • Sep 28, 2005
That is just crazy talk.. The suspension allows for weight transfer (drag racing) for better traction, absorbs bumps (street driving)... Without it you would probably need to wear a mouth gaurd when driving around.
Now for this problem that you are having: When the pinion hits the subber, are you getting on the car? If this is what's causing it, I see you having two choices:
1) Installing stiffer rear shocks (and quad shocks)
2) Installing stiffer rear bushings on the UCA's.
strokedandblown
Banned
May 3, 2005
555
USA
Sep 28, 2005
  • Sep 28, 2005
i have red bushings? i think there special but im not to "good" with susp. any links to hard bushings, this intrests me.
im not running quad shocks. and stiffer shocks, maybe ill see if mine could be set stiffer. i was hoping someone knew what springs i can put in there. right now the top 4 or 5 coils are literally pilled on top of eachother at normal ride hieght.
T
TheRipper
30
  • Sep 28, 2005
Sounds like your springs are to soft for the weight.Did you put them in there mainly to lower the car?If so how much did it lower it?You might try taking your stock springs and cutting 1 coil off each one."use a cut offwheel or chop saw not a torch"One coil should equal about a 2" drop and give you a stiffer spring where maybe it will not bottom out so much with the added system in the back.
C
SN95 Another Coyote swap list
  • catkiller
  • May 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 8, 2026
bjornsn95
New Products From J&M Products - 1979-1998 & 1999-2004 Race/Extreme Duty Rear Lower Control Arms
  • J&M Products
  • Oct 9, 2025
  • Vendor Sponsor Forums
Vendor Sponsor Forums Oct 9, 2025
J&M Products
A
SOLD For Sale: 1993 Ford Mustang Cobra Modified
  • anjteal93
  • Sep 5, 2025
2K
Fox Body Mustangs For Sale (1979-93) Oct 26, 2025
Mindseye007
SOLD For Sale '92 LX Street/Drag car - WV
  • MikeyMustang
  • Apr 12, 2025
2K
Fox Body Mustangs For Sale (1979-93) Dec 31, 2025
MikeyMustang
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
