  • SN95 4.6L Mustang Tech
Need suggestions for 4.6 build
  • Thread starter Thread starter maxpower
  • Start date Start date Nov 3, 2007
M
maxpower
  • Nov 3, 2007
hey guys i just wanted your opinion on a few things. Currently i am building a 4.6 non pi motor with pi heads and intake. my quesiton is cam choice. this will be a all motor build and i am looking at the vt stage 2 cams. http://www.vtengines.com/store/index.php?main_page=product_info&cPath=11_1_8&products_id=2
i was also planning on using high load crower spring http://www.vtengines.com/store/index.php?main_page=product_info&products_id=1541
and jsut steel retainers becuase the cams are going to drain me of alot of cash. http://www.vtengines.com/store/index.php?main_page=product_info&cPath=11_1_6&products_id=1519. ].
does anyone have these cams? Another question i had was will there be any concern with PVC with the big cams and the PI conversion. i know the compression will be at like 10.5:1 with the swap. If anyone has any input, suggestions, or think this is a good setup please let me know. thank you for your time.
Superhereaux
chicks make me feel inadequate
538
South Texas
Nov 3, 2007
  • Nov 3, 2007
sounds like a good setup
alot of people on here running VT cams with no problems and i don't see why the PCV system would be of any concern, of course if the car has 70,000 miles on it you might want to change the pcv valve anyway
2002BLGT
Well-Known Member
Dec 18, 2003
2,945
Bedford VA
Nov 3, 2007
  • Nov 3, 2007
get ported heads if you can afford it
M
maxpower
  • Nov 4, 2007
no no no no hahaha PVC (piston to valve clearence) with the head swap. that is what i am concerned about.
Superhereaux
538
South Texas
Nov 4, 2007
  • Nov 4, 2007
sorry, i just thought you got your letters mixed up (pretty normal occurance around here)
as far as your actual PVC concern, i'd like to know as well
blckstng96
208
  • Nov 5, 2007
im pretty sure there are no piston to valve problems with that cam even with a non pi piston.i have those cams but i also have a lot of other stuff too and my pistons are dished.id say to go with it though,pretty desirable cams and makes good power.deff need the springs though for sure.
M
maxpower
  • Nov 6, 2007
Ok, I got a hold of VT cams today and they said that there will not be any problem with PTV contact since their cams do not have any advance in the grind, some high lift cams have up to 6 deg. Also the high load springs are a good idea just to be safe.
4.6 engine "build"
  • Levi.Productions
  • Dec 25, 2019
10K
SN95 4.6L Mustang Tech Jan 7, 2020
08GT500
03 GT Forged Internals info ect.
  • Borla2K3
  • Jan 24, 2019
2K
SN95 4.6L Mustang Tech Jan 25, 2019
Dark04GT
J
K-member Question Racecraft
  • jAEded
  • May 4, 2014
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 5, 2014
90lxcoupe
Help Looking For Cs6/8 Hood?
  • trigga415
  • Sep 29, 2014
  • 2005 - 2009 Specific Tech
2K
2005 - 2009 Specific Tech Oct 2, 2014
trigga415
Suspension SVE Rear Lower Control Arms (RLCA)
  • nine2oneGT
  • Dec 22, 2012
14K
SN95 4.6L Mustang Tech May 2, 2019
Boricua86
