Well since nobody can figure out exactly why my clutch has a burning clutch smell and yet not slipping has drove me to buy a KC Cobra clutch assembly, aluminum driveshaft, and new OEM clutch cable...I'll need the clutch eventually anyways in place of the stock NAPA one...
I was just wanting some tips to make the job go easier for those who have did it...
What are the exact torque specs I should use when bolting the flywheel, pressure plate, etc...and the only bolts i need to put loctite on is the flywheel bolts and driveshaft bolts...
Do I need one of those tailshaft seals where the driveshaft goes into the trans...
Even though the pilot bearing was replaced last year when installing the NAPA clutch I figure I will replace it again (renting a pilot bearing tool) if the KC clutch comes with it...
I'm going to get the flywheel resurfaced even though last year the flywheel was smooth...(the previous owner had recently did a 5spd swap a year or so earlier)...
Any tips on getting the clutch cable off and properly adjusted if the OEM clutch will fit on my UPR quadrant...I have a UPR firewall adjuster if that matters...
Thanks for the tips and suggestions...
...oh well I got a good price on them... $169...
