Need to borrow your creative minds...
  • Thread starter Thread starter nmcgrawj
  • Start date Start date Aug 18, 2008
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Aug 18, 2008
  • Aug 18, 2008
Im trying to figure out a way to ignite candles and have them in the shape of a name....
But i cant figure out a way to connect each wick. I dont want to have to light each and every tea light
So then i started thinking about trying to engrave/carve out a piece of wood, then put a string in it, to act as a wick, and to have the string in the shape of the name in cursive(so every letter is connected.
Anyone understand what im trying to do? Any ideas? What should be done to the string to speed or slow down burning if i did go the "carved" route?
Any other ideas?
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Aug 18, 2008
  • Aug 18, 2008
Or how about if i got little wooden block letters? but then i'd need a way to ignite them....hmmm.....
Bosko5.0
1,067
longwood, FL
Aug 18, 2008
  • Aug 18, 2008
You wouldn't be able to light them all like that. use a blow torch just don't point at candle or else it will melt.
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Aug 18, 2008
  • Aug 18, 2008
Bosko5.0 said:
You wouldn't be able to light them all like that. /QUOTE]
Which idea are you referring to?
sn-95matt5-0
170
  • Aug 19, 2008
how large do you want it and how long does it need to burn.
get a large piece of would. right the design you want on it with a large sharpy maker. with a drimel or rotor cut out the design. the put camp lantern oil in it. it should light and burn for a decent amount of time depending on how deep you cut the design.
you could also soak the wood block letters in the oil and they should all ignite if they are touching.
nmcgrawj
Advanced Member
Sep 28, 2003
3,651
Indianapolis, IN
Aug 19, 2008
  • Aug 19, 2008
not big. Maybe 8.5"x11".
Would that oil ignite easiest?how about 99% rubbing alcohol? Where do I get that oil from?
Thanks man!!
blksn955.o
3,263
st.louis mo 314
Aug 19, 2008
  • Aug 19, 2008
This is not going on food is it?
If its going to be on the ground or something I would use foil with the letters bent (think V or U shape in the foil) into it leaving a channel in the letters. Then use whatever you want to light.
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
J
  • JRC99
  • Apr 19, 2025
JRC99
J
New daily driver help needed.....not a mustang but mustang drivetrain.
  • Wayne Waldrep
  • Jun 17, 2024
  • Other Auto Tech
  • 3 4 5
6K
Other Auto Tech Jul 28, 2024
manicmechanic007
SN Mustang Magnum T56 swap
  • revhead347
  • May 24, 2024
  • 1994 - 1995 Specific Tech
6K
1994 - 1995 Specific Tech Jun 28, 2026
GearHeadGuy
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
19K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
