Need to decrease my brake power...
  • Thread starter Thread starter MikeC
  • Start date Start date Dec 9, 2008
MikeC
240
SLC, UT
Dec 9, 2008
  • Dec 9, 2008
I have a pieced together M2300K kit on my 92 (Cobra brakes ft and rear). I have a 93 Cobra MC and booster. The brakes have too much power, very little pedal pressure is required to stop the car. I lightly touch the brakes and it stops. I don't want to change the booster to a smaller one because of the effort it took to get the 93 Cobra booster in the car in the first place. So I'm thinking a smaller diameter master cylinder may help. This should reduce the pressure and increase the travel a little. Is this correct? Any suggestion as to which MC is smaller in diamter? I believe the 93 Cobra MC is 1" diameter, do any others have 7/8" or 15/16" bore and the same fitting sizes at the 93 Cobra?
D
Deleted member 87397
Dec 9, 2008
  • Dec 9, 2008
Did you happen to get the adjustable proportioning valve that comes with the 2300 kit? Sounds like maybe you just need to tweak that a bit and if you don't have one you might want to put one in and see if you transfer a bit more to the rear instead of the front.
MikeC
240
SLC, UT
Dec 9, 2008
  • Dec 9, 2008
I have the adjustable proportioning valve and have gutted the stock valve. I originally used the 93 Cobra MC with the stock booster and it was under powered so I put on the 93 Cobra booster and now it is overpowered. I believe the adjustable PV is set correctly. The rear locks up just after the front.
63bird390
58
San Antonio TX
Dec 10, 2008
  • Dec 10, 2008
master cyl
for a harder pedal you need a bigger dia master cyl mabey 1 1/8" this link will have a crap load on brake info.
Master Power Brakes - Reference/FAQs: Master Cylinders
MikeC
240
SLC, UT
Dec 10, 2008
  • Dec 10, 2008
I guess I didn't explain what I want very well. I want to change it so I have to apply more pressure to stop the car. Right now the weight of my foot on the pedal stops the car. It is like it's over boosted. Sometimes I forget and apply "normal" pressure on the pedal and it almost locks the wheels up.
D
Dec 10, 2008
  • Dec 10, 2008
I think 63bird is on the right track. A larger diameter is going to create less pressure and cause you to have to push the pedal harder. By hard pedal I think he meant having to push it harder.
67coupe
658
402
93
Huntsville, AL
Dec 11, 2008
  • Dec 11, 2008
MikeC,
I replied to your thread on corral as well.
Yes, increasing the MC bore will make your pedal less sensitive.
I know you don't if you want to, but putting the stock booster back in would also increase pedal effort. The whole cobra vs stock booster has been debated many times. I would suggest a search.
Mustang5L5
Mod Dude
Feb 18, 2001
43,332
18,059
224
Massachusetts
Dec 11, 2008
  • Dec 11, 2008
I beleive 94-95 GT's use a 1 1/16" bore.
93 Cobras use a 1" bore
94-95 Cobras use a 15/16" bore.
Try swapping the cobra unit out for a 94-95 GT/V6 unit
MikeC
240
SLC, UT
Dec 11, 2008
  • Dec 11, 2008
67coupe said:
MikeC,
I used the stock booster with the 93 Cobra MC for several months. It was impossible to lock the wheels up. And I may never be able to get the 93 Cobra booster back out of the car, it did not want to go in there.
I think I may be stuck because it looks like I want to different things.
1 - I want to increase the pedal stroke - smaller bore MC to move less fluid.
2 - I want to make it less sensitive - larger bore to decrease fluid pressure.
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
Fox Brake pedal too stiff
  • keel
  • Sep 21, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
General karthief
Brakes FOX BRAKES ISSUES
  • PonyGTrider
  • Jan 11, 2026
  • 2 3
2K
Fox 5.0 Mustang Tech Jan 31, 2026
Mustang5L5
Brakes Front brakes sticking - 1988 5.0
  • 302Blue
  • Oct 18, 2024
Fox 5.0 Mustang Tech Oct 19, 2024
ustacould
D
Brakes 88 LX 5.0 - help! no brakes
  • DRGunn427
  • Feb 26, 2025
Fox 5.0 Mustang Tech Feb 27, 2025
nickyb
