I have long tubes and need to know if my tranny needs to be removed in order to do a driveshaft swap. I have a FRPP aluminum and need to put it in. Thanks.
thanks for the quick responses. yeah the early 4v cobras had the vibe-shaft. i am not mechanically inclined at all, is this something i could do with standard tools and jackstands in my driveway?
its a snap as long as the bolts arnt rusty. soak them with some oil for a while first. and have a rag close by cause the tail shaft on the trans will leak.basic tools will work fine.
In short, Ford fixed the problem by using driveshaft imbalance to offset pinion flange runnout. If you put in a well-balanced drive shaft, you could end up with a vibration, because it no longer offsets the pinion runnout.
That's all fine and dandy, but all the poster asked was whether his transmission needed to be removed in order to perform the swap. We all know about the vibration problems on IRS equipped Cobra's... hell I had to have my whole DS & IRS replaced and I still have a vibration at 80+ MPH.
