OK HERE IT IS, IN BLACK AND WHITE.
FLEXPLATE - Device used to start the engine with an AUTOMATIC trans and provides a coupling point via 4 studs to the torque converter.
FLYWHEEL - Device used to start the engine with a MANUAL TRANNY and provides a coupling point for the clutch assembly.
You will NEED to use THIS flexplate:
P/N B-23115 $143.33 (retail) $129.00(racer's net)
FORD FLEXPLATE 141 TEETH 50 OZ/SFI
It can be found on Art Carr's website at:
http://www.artcarr.com/catalog/ford-B-D-Y.php
or
http://www.artcarr.com/ - main page.
BE SURE YOU HAVE THE CORRECT TORQUE CONVERTER WHICH WILL HAVE A 9 1/4 BOLT CIRCLE THAT BOLTS IT TO THE FLEXPLATE.
IF the bolt circle on your torque converter is ANY OTHER PATTERN -STOP- let one of us know so we and re-direct you down the right path.
Also check the P/N on the Automatics's bellhousing if you not 100% sure it is a II bellhousing. Numbers should read D5ZP-7976-AA. To see these numbers, you'll have to remove the bellhousing from the tranny to see the numbers. (kinda stupid on Ford's part)
Also be sure to have the II specific block plate. OTHER PLATES WILL NOT WORK. The starter is clocked to a different position on the bell housing, so you will need the II plate with the II bellhousing.
May, but not 100% sure, need to change to correct starter aswell.
And that's that, plain as black and white...
