needed to convert to 31 spline???
Axles and a carrier.
You can get a FRPP 31 spline Trac-loc for $189 from www.gefracing.com
(you will need lube and friction modifier to go with it)
31 spline axles can be had for about $235 from www.moserengineering.com
(you will have to have the exciter rings on the end of the axles removed from the old and pressed onto your new axles)
If you have the extra bucks you can pick up an axle girlde and safety loop.
