Needing Help Fast! 06 Gt Overheating 4.6l
Trent_97
23
Hey guys I have a 06 GT that has started running hot when it sits and idles but when i drive it it goes back to normal? Im not use to these since im new to them what could it be? I need it fixed Asap.
Sounds like the electric cooling fan isn't working. Switch on the AC and see if that triggers the fan to work. If it doesn't, the problem is likely to be either a burnt fan relay or a burnt connector between the wiring harness and fan.
