Neutral safety switch.
65fastbackresto
1,229
AR
I removed the old tranny from my 65. Put in one thats more modern, but also a C-4. Pretty sure the wire for the neutral safety switch wont plug back in the newer tranny. Any easy ways around this problem? I`m running an MSD 6AL ignition, as long as it has power when the key is on, is this gonna work right?
You can jump the connection very simply by using a 4" wire with bullet connector on each end. I would suggest properly wiring the switch for your new transmission in the long run, but this will allow you to get her running.
