Well, since I've supplied power to the Thundersnake after finishing the EFI wiring conversion, I've found that that car itself had some electrical issues unrelated to my wiring handywork.
First, the directionals stopped working. They HAD been working, but no more. So I checked into it and the feed fuse wasn't getting any supplied power, it was dead on both sides. I pull the fuse box apart, and trace the wire that feeds that fuse, and it goes to the ignition. So I drop the column, and pull the switch off. It's not switching power to that circuit when you turn the key. "No problem" I think, since I had a spare ignition switch from the 76. Ah, but not so fast, the plug is different on 77-78s
. So I literally split both switches open and made them into one good working switch. Ok, that problem is solved...
Next up, when you turn the parking lamps on, the right turn signal bulb in the dash lights up. I also noticed that the right front turn signal bulb is VERY dimly lit. So that's a good place to start. Quick test with the DVOM verifes a short from the parking lamp circuit to the ground. So now I start checking the rest of the circuit. I pull the headlamp switch plug, and check it there, shorted. So it's time to check all legs of the circuit from there. I disconnect the engine harness at the firewall, and it's still shorted, so that rules out anything forward of the firewall. Then I start checking the two areas behind the dash that wiring goes to, disconnect them, still shorted. That rules out the dash. I disconnect the harness that leads to the rear of the car, no more short. So now we know it's somewhere in that harness. Next plug in line, is the taillight harness. Disconnect that, no short in the harness running to the rear of the car. I check the taillight harness itself, shorted. Now I JUST installed this taillight harness, replacing the one that was in the car, because the sockets were crap on it. BUT, the problem was there with the old harness too. So I check the old harness from ground to the parking lamp circuit, and it's shorted too!
So all this work, and I have two shorted taillight harnesses. LOL.
. So I literally split both switches open and made them into one good working switch. Ok, that problem is solved...Next up, when you turn the parking lamps on, the right turn signal bulb in the dash lights up. I also noticed that the right front turn signal bulb is VERY dimly lit. So that's a good place to start. Quick test with the DVOM verifes a short from the parking lamp circuit to the ground. So now I start checking the rest of the circuit. I pull the headlamp switch plug, and check it there, shorted. So it's time to check all legs of the circuit from there. I disconnect the engine harness at the firewall, and it's still shorted, so that rules out anything forward of the firewall. Then I start checking the two areas behind the dash that wiring goes to, disconnect them, still shorted. That rules out the dash. I disconnect the harness that leads to the rear of the car, no more short. So now we know it's somewhere in that harness. Next plug in line, is the taillight harness. Disconnect that, no short in the harness running to the rear of the car. I check the taillight harness itself, shorted. Now I JUST installed this taillight harness, replacing the one that was in the car, because the sockets were crap on it. BUT, the problem was there with the old harness too. So I check the old harness from ground to the parking lamp circuit, and it's shorted too!
