• Community Forums
  • Regional Forums and Event Information
NEW 60' TIMES??
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date May 18, 2004
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
May 18, 2004
  • May 18, 2004
anyone have any idea on how much i can gain on my 60' times. i was running between 1.9's (high) to 2.1. since these i have got drag radials and upper and lower rear control arms? one other thing i cant get into the part to sell my c&l 76 mm for some reason anyone intrested in it? it's for a 95 with stock injectors it only has 4 passes on it. call me at 360-241-8025 if ya want it and for a price, or i might trade ya for two 17x9 rims. peace
john
T
Turbosnake95-wk
94
  • May 18, 2004
My best was a 1.8 on the Nitto's and all I have as far as aftermarket suspension is Ibach pro springs and MM full lenth sub frames connectors.
Will
Tylerb59
Banned
Mar 7, 2003
1,895
Arlington, WA
May 18, 2004
  • May 18, 2004
Remove your front sway bar (or at least loosen it a bit)
Relocate your battery to the rear, as well as a tubular K member to save weight in the front.
Softer rear springs (drag springs)
Adjust the driveshaft -> diff angle on the UCA (Assuming they're adjustable) to be straight as possible...
Traction and a little practice... hehe
89MustangGX
I have nothing productive to add!
Jul 3, 2001
10,262
Mill Creek, WA
May 19, 2004
  • May 19, 2004
It all depends on the rest of the setup. There are drag radial cars pulling 1.3 short times with the right setup. With that said, a 1.9 60' is pretty good for a street tire. With a stock type suspension and just a set of control arms I would guesstimate you could maybe knock a couple tenths off of that, so 3-4 tenths on the big end.
stock50LX
Curmudgeon
1,858
University Place, WA
May 19, 2004
  • May 19, 2004
I find that with DR's you are a the mercy of track prep. If the track is well prepped with VHT you should be able to pull some 1.70's. If it is not prepped, you are not likely to see any improvements. Try racing with the cars with slicks (pro bracket). Let them lay down some rubber for you.
Suspension Foxbody ride height change after installing new control arms
  • Mhalc1
  • Jan 3, 2024
9K
Fox 5.0 Mustang Tech May 10, 2024
Mhalc1
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
19K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
K
SOLD 1988 Ford Mustang GT, lots of upgrades, Maximum Motorsports Suspension PRICE DROP $6800
  • kuhl0040
  • Aug 18, 2021
4K
Fox Body Mustangs For Sale (1979-93) Sep 20, 2021
J
What's it Worth? 93 coupe turbo
  • junkyardwarrior
  • Jan 16, 2022
  • What is it Worth?!?!?
2K
What is it Worth?!?!? Jan 28, 2022
Middleagecrisis
M
A
Progress Thread alwayshi 00 GT supercharged build
  • alwayshi
  • Nov 7, 2019
8K
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2020
Deleted member 38176
D
  • Community Forums
