  • SN95 V6 Mustang Tech
new a/c compressor..engine running hot?
  • Thread starter Thread starter matt1517
  • Start date Start date Jun 18, 2009
matt1517
42
  • Jun 18, 2009
OK so I installed a new compressor and replaced my a/c system, it works like a ice box. Now my problem is that the new compressors pulley diameter was like an inch bigger, so I had to find a new belt. I finally got one. It went from a 985 to a 990 which fit nicely. When I turn the MAX AC on it heats up to "m" on normal, which is quite hot I think. then again it didn't have ac when I bought the car, so i don't know whats normal when its on. I bought a new thermostat ( a 180deg instead of 195) so it might start to cool down better. I will do a radiator flush before I fix this. Is there anything else that I can do? Should I have gotten a 160?
I am not condemning my thermostat, it would need to be replaced anyway being 13yrs old.
95 v6 131k (avg)
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Jun 18, 2009
  • Jun 18, 2009
Put a mechanical gauge on it if you have concerns about temperature. The stock gauges aren't renowned for their accuracy, but I wouldn't be too worried if my gauge was reading on the M of normal. I think that's about where mine runs normally, without the AC on.
matt1517
42
  • Jun 18, 2009
Wow, without ac yours is close to m? Without ac mine goes straight up and down on "r", never wavers. Even on a solid 4 hr trip it never changed (when I didn't have ac).
Aren't you concerned about the heat?
BlownFiveLiter
18
108
Chicagoland
Jun 18, 2009
  • Jun 18, 2009
Not really. Unless it's set at max AC, the fan barely ever goes into high speed. That's not until 218° according to the EEC.
matt1517
42
  • Jun 19, 2009
I forgot to mention when I did my AC repair I unhooked the battery, therefore the computer reset and it had to relearn my habits. Took it for a drive with max AC on and it stayed pretty much on O or R never to far beyond. I guess this would explain the heat.
MustangLX-5.0
856
Lehigh Acres Fla.
Jun 19, 2009
  • Jun 19, 2009
StangGT1995 is right about the accuracy of these gauges. And the accuracy gets even worse as the car ages. Over time corrosion can form on many hidden grounding points. Think of bare metal grounds that accumulate slight amounts of rust. Rust creates resistance and affects sesnsitve circuits like gauges. Over time, the readings can be up to 15 - 20 degress off on a temp gauge. Bad grounds and excessive current draw can also cause negative return voltages. You can find the amount of negative return voltage by using a voltmeter and measuring by connecting to two separate grounds. Take the negative battery terminal and the ground connection near the passenger side headlamp. If the grounding between the two is bad, you can have voltages of up to 1 volt. Cleaning ground points can help alleviate some of this. Now, to see the affect of bad grounding on a gauge, drive your car around till it's well into normal operating temperature (near the middle). Now, idle it someplace safe and note the gauge reading. Also note if the cooling fan is on or off. If it's off, read the gauge then flip the vent switch to any of the positions that engage the compressor (eg.. Defrost). What you want to do is flip the switch on for 2 seconds and and then flip it back off. Just long enough to cause the fan to kick in but not to engage the compressor clutch. Keep watching your temp gauge the whole time your doing this. When the fan kicks on, the temp needle can nudge to the right a little. This is from the high current draw of the fan creating a negative voltage return, and in the cases of corrosion. Sometimes the effect of this can be so great that the gauge needle can move up to the amount of one full letter in "NORMAL" . Where it normally would be on "R" ,the fan kicking on nudged it near the "M". Now, while the fan is still on, press the rear window defroster button (if you have it) and note the temp needle. Same thing, but combined with the fan on the needle moves even more. After the fan shuts off and the load drops, so does the needle.
My 96 has been doing this throught the past 3 years. It's only been getting slightly worse over time. This may or may not be relevant to your issue but I thought it would give some insight on the possible cause of your high temp position.
Has your stang always had AC equipped? Or did you do a fresh install and mod a vehicle that didn't ever have AC. Just curious, though I highly doubt they make them that way these days. AC is a factory no-charge option.
As for T-stats, 192 degree is the norm. Going to a lower degree t-stat such as 160 may decrease your fuel economy (not sure if you care about that hehe) . I have removed mine indefinately because of cooling system pressure issues. It's not killing my fuel efficiency much as I live in Florida and it gets hot here all the time.
On a last note, Idling with your AC on for extended periods in hot weather can greatly increase the negative return voltage effect. The alternator gets very hot and voltages are reduced from heat stressing the diodes and regulator circuit. I used to idle in my car on my lunch breaks at work very often. After awhile, the temp gauge would get well into the "M" or a pinch past that. Sitting there for extended periods doesn't help heat dissipation any bit. It can't cool off very well and do no more than blow hot air at things that are already hot.
matt1517
42
  • Jun 19, 2009
It had AC equipped but the guy who had it last burned out the compressor. There was no oil in it or the accumulator. So yes I did do a ground up fresh install. I was on the way to the store with Max AC on and the car heated up rapidly until it hit m and leveled out. I turned off the AC and of course it went back to normal ("r"). i try not to idle with the AC to long. When I go to lunch I sit with the windows down, I have this privilege because I work the graveyard shift.
Lately It hasn't reached "m" in fact it rarely gets to the early "r" unless I drive it for a while.
BlownFiveLiter
18
108
Chicagoland
Jun 19, 2009
  • Jun 19, 2009
It'll run a little warmer with the AC on, due to the increased parasitic drag on the engine. If it's not climbing up into the red area of the gauge, there's probably no reason to worry. If you put it on max AC, the high speed fan will run by default, so that should help with cooling the engine. You could probably get away with keeping it on even while sitting, with no ill effects.
2001 v6 New compressor issue
  • badmech
  • Apr 30, 2026
SN95 V6 Mustang Tech Apr 30, 2026
badmech
9
91 LX 5.0 getting hot when a/c is running
  • 91lx14gt5.0s
  • Jun 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 4, 2026
manicmechanic007
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
M
  • mnky99
  • Sep 5, 2025
mnky99
M
J
V-6 thermostatically controlled cooling fan - on when cold - new behaviour
  • jacekk
  • Oct 1, 2025
  • 2005 - 2014 Specific V6 Tech
2005 - 2014 Specific V6 Tech Oct 1, 2025
jacekk
J
