New Best
Pops Fun
961
14
59
Cincinnati, Ohio
Hi
Strapped some slicks on my heavy vert and here are the results: 11.696:D
Hi, I asked a question on your last thread about your car but you must not have seen it.
I'm going about the same route as you 347 and all that jazz with a vortech.
How often do you drive the car and how many lbs are you pushing through it? I remember on your last thread you said it was a stock block and still holding up, just trying to gauge how much boost I should be pushing to be at that point or a lil lower.
EDIT: Oh yeah, congratulations on the time man! I hope to be in the mid-low 11's when my build is done as well.
The stock block hasn't been a problem yet!! How much do I drive the car.... When ever I can. The mileage sucks. it drives like stock, til the vacuum goes up about 3000 to 4000rpm. :D I get my tune checked every a year to check the fuel!! The boost just came out that way. It depends on how it breaths etc. Unless you change pulleys.
Here is my page with the different stages I took with the car. Dyno Page
Here is my latest tune. Around 12.8lbs of boost with a Vortec SQ with standard pulley.
Hope this helps just let me know if you need anything else. My son with a dart block makes 580rwhp on his, bigger injectors etc. Afraid to turn mine up :rolleyes: Stock block.
Man that 330 time is awesome!! :D j/k
Congrats! Very nice 60' time. :nice:
Well slicks are the answer to that..:D My best time on DR's was 12.089 with a 1.90 60 ft. Put slicks and magically a 1.54 . I still hit the limiter in 1st, 2nd and third, limiter is set at 6300rpm.
My first run I forgot to lower the pressure ran with about 25#, and got a 1.75, 60' and ran a 12.08 @121 mph. Same as my DR best. :D
ok i dont mean to sound like a n00b or anything... but what does the 60ft and the 330 stand for? is the 60 ft basically how long it takes u to get outta that box? :shrug: never went drag racing so never bothered to learn
The 330' is listed as .000 on his timeslip, so I was just kidding around with that comment. ;) And you're pretty much right on the 60' time. I usually get around 1.8-1.9 with my car, so a 1.5 is pretty darn good IMO.
