New Cam help
  • Thread starter Thread starter mrfomoco
  • Start date Start date Jul 15, 2004
mrfomoco
108
The Woodlands, Texas
Jul 15, 2004
  • Jul 15, 2004
Ok so i have a 351w and I was putting in my new cam today and after i got it in I started wondering how much play back and forth should there be in the cam? I bolted the thrust plate down and the cam moves like an 1/8th of an inch back and forth. If this matters it is a hydraulic roller cam from comp cams.
gbarber
158
delaware, ohio
Jul 16, 2004
  • Jul 16, 2004
If you haven't put the timing chain on yet, there will be some play. Installing the timing chain sprocket should pull the cam pretty tight against the thrust plate. There will be a little play, but nowhere near an 1/8".
brianj5600
1,964
Middle TN
Jul 16, 2004
  • Jul 16, 2004
That is too much movement. One of my books says .001-.007 of an inch. The other says .0005-.0055. At the .125 endplay you have the spinning cam will get into something. The ignition timing will change as the cam moves foward and back as well. The cam sprocket may not work with your block. Consult the timing set manufacturer.
mrfomoco
108
Jul 16, 2004
  • Jul 16, 2004
gBarber is my new hero
D
Engine HO cam in non HO roller block ‘93 f150
  • DanC1993f150
  • Mar 21, 2026
Fox 5.0 Mustang Tech Mar 29, 2026
General karthief
H
Ongoing Battle With Hydraulic Lifters
  • hailer06
  • Jun 8, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 9, 2026
Fox won't crank over and fuel pump won't kick on.
  • djj62478
  • Jun 7, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
General karthief
9
Forced Induction Prepping for supercharger on non-stock build
  • 91fox427
  • Nov 25, 2025
Fox 5.0 Mustang Tech Jan 5, 2026
Qtrhrse23
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
