Hi all, I am having a few probs trying to get the clutch working.I will list what ive done and tried so far.
New clutch put in and worked OK. Tranny (T-5) was rebuilt less than 100k after install.
Installed new tranny and ford racing clutch cable (double hook quad) no firewall adjuster.
When trying to adjust the clutch it doesn't matter how loose or tight i adjust the cable it feels the same.tough to get into gear.All 4 tires are in the air , while I'm trying this.I cant get it into any gear without the tires starting to spin.If I pull the E-brake to stop them the car stalls.I can push it hard into first without grinding but not without tire's spinning.Reverse grinds.Everything worked OK before new cable and trans rebuild. Could it be clutch is a bit sticky from sitting? would putting rear tires on ground break it loose? I have pulled the tranny back out to inspect the clutch , and it all looks good.
Any help appreciated. Thanks
