I recently upgraded my front manual all drum brakes to power assist with new SSBC 4 piston front discs in the front and the original drums in the rear. I did an extensive write-up on the swap in this thread:
http://forums.stangnet.com/showthread.php?t=657372
The reason for the write-up was because there have been questions about fitment on 67/68 Stangs using the JMC hydraulic clutch setup. The good news is it fits (see write-up), the bad news is I can't for the life of me get the brakes to work properly and I'm extremely frustrated. The problem is when I press the brake pedal, the stopping power is extremely weak. I have to use a lot of force on the pedal and it seems like the calipers are not applying much force to the rotor. I can stop, but it's very poor performance to the point I don't feel safe driving the car. The old manual drum brakes performed much better. I also don't think the power booster is working properly and would like to know how to verify it is working? I know something is wrong since this SSBC Force 10 kit is a high performance piece. I haven't called them yet, but will if I can't figure it out with the help from Stangnet. Here's what I have done:
- Ensured the system was properly bled and have a firm pedal.
- Initially used the original distribution block that was in the car, but since replaced it with the small unit that came with the SSBC kit - no change.
- Replaced the master cylinder that came with the power booster I bought private sale (was brand new OEM style with Bendix Booster) with the unit that came with the SSBC kit. The kit I ordered frome SSBC was for manual disc brake since I picked up the power booster seperate. Would this matter?
- I checked the vacuum from the port on the intake that is connected to the power booster and I'm pulling a solid 18 inches.
- To also be clear, part of my swap included changing the pedal to the correct OEM power brake pedal (see write-up).
