  • 1994 - 1995 Specific Tech
new EGR delete tip!
  • Thread starter Thread starter CARJACKED
  • Start date Start date Apr 22, 2005
1 of 2 Next Last
C
CARJACKED
47
  • Apr 22, 2005
Everyone knows that you need to keep the plunger depressed half way to avoid the CE light. I was looking around the carhole last night for something that would work and...
Take a Beer bottle cap. Bend it in half (like a taco) stick the plunger end in the taco's opening and duct tape the taco down Where the edges of the cap meet the plunger housing. This will keep the plunger in the half-way position.
Sorry I didn't take any pics.
davins130
424
  • Apr 22, 2005
haha
AZ95GT
326
Arizona
Apr 22, 2005
  • Apr 22, 2005
Can anyone elaborate?? I have the cel problem! Any pics? Other tips?
C
CARJACKED
47
  • Apr 22, 2005
To be clear...This is all about EGR deletion, so assuming that you CEL is due to the deletion of your EGR from the intake manifold...
The EGR assembly that you removed from the manifold has a sensor attached to it. The sensor is the part that pluged into the wiring harness and is attached to the assembly by three small bolts. Remove the three bolts. You will now see a plunger that moves in/out. Use some method (like the taco method above) to keep the plunger half way and plug this sensor back into the harness, just wire tie it out of the way...no more CEL.
Mrgreen94gt
SIMMA DA NA!!!
448
West TN
Apr 22, 2005
  • Apr 22, 2005
I just have it wedged against the firewall. Seems to work fine. It's only popped out once, and that was probably due to me messing around in that area.
Dan95-5.0
1,110
Manitoba, Canada
Apr 22, 2005
  • Apr 22, 2005
I used the same method as RIO with the hose and wire nut.
i used the rubber hose from the AIR delete
dont know if its going to work yet because i'm still working on the car
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Apr 22, 2005
  • Apr 22, 2005
i used a piece of nylon with a hose clamp to keep the plunger down. i also used zach's advice about the penny to plug up the hole in the header
the total to delete the EGR cost me .01
urban96
3,464
Syracuse, NY
Apr 22, 2005
  • Apr 22, 2005
AZ95GT
326
Arizona
Apr 22, 2005
  • Apr 22, 2005
Thanks guys, I actually have not removed my egr crap yet... I had my codes run a few weeks ago and they said it was the egr was stuck shut...? weird any ideas??
Dan95-5.0
1,110
Manitoba, Canada
Apr 22, 2005
#10
  • Apr 22, 2005
  • #10
how did you do that with the penny????
i need to cap off the egr and so far no luck of removing it.
urban96
3,464
Syracuse, NY
Apr 23, 2005
#11
  • Apr 23, 2005
  • #11
remove the bolt, insert penny, tighten botl
you can also use some JB-Weld for added security
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
Apr 23, 2005
#12
  • Apr 23, 2005
  • #12
You'll have to cut that tube that runs from the header to the EGR valve, take off one of thoes nuts, insert a penny, tighten it back down.
M
madams74
664
Maryville, TN
Apr 23, 2005
#13
  • Apr 23, 2005
  • #13
Guys I have a quick fox for your problem. This fix will allow you to remove the EGR completly with no left over parts under your hood. I cant do this test since I am working out of state at the time or I would show you the right method.
You need to get a voltage meter/tester that has an OHM scale. You should see on your plug for the connector some wires. When you allow the vacuum to move the EGR it changes the resistance on those wires. This change allows the computer to know that it has been succesful in moving the plunger. You have to find the resistance that it reads when it is shimmed with tape or whatever method you guys decide to use. Then go to Radio Shack and buy a 1/4 watt resistor that matches the correct resistance. You should only have to cut those 2 wires and connect the resistor from one wire to the other. This tricks the computer into thinking it has a sensor on it. Should help clean up your engine bay. If you dont cut the wires then you may be able to cram the resistor into the plug.
BlueOvalStangGT
2,849
Tampa Florida....USF!!!
Apr 23, 2005
#14
  • Apr 23, 2005
  • #14
I used a nickel to cap the bung and alot of JB weld. For the CE light, tweecer!
F
fastf50rd
720
mass.
Apr 23, 2005
#15
  • Apr 23, 2005
  • #15
I just depressed the plunger half way, took a pistol drill with a small ass drill bit, drilled a hole through it, and stuck a paper clip through. It's about as clean as you can get with the sensor still in tact.
95CobraMike
1,046
Lima OH
Apr 23, 2005
#16
  • Apr 23, 2005
  • #16
whats the point of EGR delete?
what does the EGR do?
urban96
3,464
Syracuse, NY
Apr 23, 2005
#17
  • Apr 23, 2005
  • #17
my tube broke when swaping intakes and this was cheaper/easier then buying a new one
95CobraMike
1,046
Lima OH
Apr 26, 2005
#18
  • Apr 26, 2005
  • #18
what does the EGR do again?
what is the point of deleting it?
C
CARJACKED
47
#19
  • Apr 26, 2005
  • #19
Cleans up engine bay.
Allows use of Fox body headers.
EGR injects hot exhaust gases into the intake.
95CobraMike
1,046
Lima OH
Apr 26, 2005
#20
  • Apr 26, 2005
  • #20
wouldnt that hinder performance?
isnt cooler air better?
1 of 2 Next Last
Progress Thread Giving an abandoned 88 GT project a new chance at life
  • jaketractor
  • Jan 9, 2025
2K
Fox 5.0 Mustang Tech Jul 20, 2025
1969, 1970 mustang heater box repair/replace instructions (no AC)
  • 70mstang
  • Apr 9, 2023
6K
Classic Mustang Specific Tech Apr 9, 2023
70mstang
Took some pics, i do really own a mustang...
  • 2000xp8
  • Jun 20, 2023
  • 6 7 8
21K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2024
Mustang5L5
9-23-2020 Positive Post / Protest Related Situation
  • kiddiccarus
  • Sep 24, 2020
  • Off-Topic Hangout
Off-Topic Hangout Sep 25, 2020
kiddiccarus
On3 Performance Install Tips
  • flstang65
  • Dec 15, 2019
12K
1996 - 2004 SN95 Mustang -General/Talk- Mar 17, 2023
atomicfox236
A
