  • 1994 - 1995 Specific Tech
New engine, Coolant issues
  • Thread starter Thread starter Yellow302
  • Start date Start date Sep 12, 2007
Yellow302
789
NJ
Sep 12, 2007
  • Sep 12, 2007
Problems, a small hole about half way up in my overflow tank. Tank gets filled to the top and overflows all over my engine. Radiator and engine are filled with nothing but air and a little anti freeze.
What could be causing this to happen. Only does this when i really romp on it.
STM1965
185
Ontario
Sep 12, 2007
  • Sep 12, 2007
When you have your rad full and the cap off do you see bubbles coming up in the rad when you increase your RPM's? Manifold or head gasket is allowing air to be sucked into the engine would be my guess.
Yellow302
789
NJ
Sep 13, 2007
  • Sep 13, 2007
well i had to use some gasket maker for the thermostat housing so its possible is keeping it closed, trying the 5 dollar fix first. New t stat and gasket.
Yellow302
789
NJ
Sep 13, 2007
  • Sep 13, 2007
changed T stat and gasket, drilled a 1/8th hole in the top to get rid of the air/constant flow...
hot glued the stock overflow and put a metal brace over the top. Drilled a new hole in the plate that bolts to the fron of the car and pulled the bottle further away from the s/c belt... cheap fix 10$$ hope it works
Yellow302
789
NJ
Sep 14, 2007
  • Sep 14, 2007
problem still happening, replaced the radiator cap, still happening...
I dont know if the radiator has a slight clog or the water pump is going bad, but the system is still getting air in it when i punch it for 5-10 secs, very frustrating.
When the car is off for 5 min it sucks all the overflow tank juice back down and the car runs fine.
Yellow302
789
NJ
Sep 14, 2007
  • Sep 14, 2007
when i rev it the only thing I see is the water swirling around, i dont see any bubles
R
coolant
  • Rudy10thsvt
  • Sep 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 1, 2025
General karthief
P
Engine Mysterious coolant leak at back of engine
  • palerider94
  • Jan 18, 2026
Fox 5.0 Mustang Tech Jan 19, 2026
AeroCoupe
J
2001 coolant issue
  • jr273
  • Jan 24, 2026
  • The Welcome Wagon
The Welcome Wagon Jan 24, 2026
Ford truck engine swap issues
  • keel
  • Jul 7, 2026
  • Other Auto Tech
Other Auto Tech Jul 13, 2026
General karthief
M
01 mustang 3.8 fuel pressure issue
  • Mhaley2006
  • May 29, 2026
1996 - 2004 SN95 Mustang -General/Talk- Aug 9, 2026
JohnKay
J
