Well, I finally got my new engine installed and running, but now I have a few bugs that need to be worked out. First of all my combo is this: 1986 mustang GT, 5 speed, 308 crate engine with TFS TW heads, TFS stage 1 cam, 75mm Pro-M mass air, 70mm throttle body, TFS street heat intake, BBK longtube headers, new 190lph fuel pump, new FMS 24# injectors, mass air conversion. The engine runs fine, except will start cutting out at 4500-5000rpm in any gear (even neutral). I have an adjustable fuel pressure regulator that is set at about 40lbs, but we have tried different settings and it makes no difference. It seems to be running pretty lean, the plugs are kind of white. Anybody have some ideas?
