I have a new stroker 331cu in a LX 5.0 Mustang. Its running rich and spark knocks if the base timing is set over 5 degrees. (With the pill out)
This is the engine.
E7 block Zero decked
AFR heads 60cc
CompCams X HR270
Cobra intake
19# injectors
Mass air meter stock 1992
Stock TB and I have now installed a 75MM
Probe ultra pistons dish ? = CR 8.7 ~ 8.5.
I replaced all the sensors when the engine was installed.
How can it spark knocking with this low CR ??
Is the ECM just flipping out over the extra air from the stroker?
Is my only option a custom chip?? I have a blower to install next spring. I just want it to run better now. I have larger injectors and a Mass air meter for the SC.
Any ideas?
This is the engine.
AFR heads 60cc
CompCams X HR270
Cobra intake
19# injectors
Any ideas?
