new engine started but no oil pressure?
pwcracer
347
Hastings, MN, USA
I started my new engine, it ran very rough, and we noticed after about 30 secs it had no oil pressure. My helper also mentioned it looked like the dizzy was oscillating a bit. I pulled the dizzy out and everything looked ok. Is it possible that the end of the dizzy went along side the hex shaft for the oil pump?
I spun the shaft with a drill and it showed oil pressure on the dash..
is it a mechanical guage or electric? if its electric check and make sure that the wire didnt come off the sending unit, and as far as the dizz not being on the shaft u would know it bc the car wouldnt start bc you would have never be able to get the dizzy past the cam gear, check and make sure that you didnt blow a fuse for the dash guages.
