New engine
Fireman255
119
So, I want to find an engine to rebuild for my 1966 coupe. It currently has a 289 with a new c-4 tranny. I want to keep the same tranny, but would like to get an engine to beef up. I don't want to race it but would like it to be impressive. Which engine should I go with and how much should I pay for a stock one from a salvage yard or such.......Or am I just retarded and need to rebuild my 289???
Thanks :bang:
A latemodel 5.0 Explorer engine would be a good find. It already has GT-40 or GT-40P heads and is roller-ready($400-800 dep. on cond.). Another consideration is an 87-95 Mustang($250-600) 5.0 or a 351W($?) of some sort. Maybe a 351C, but it would be a little more involved to switch that way.
if i remember right only the 93 Cobra, and later Mountaineer/explorer 5.0's have GT40 heads, i think the other ones use the E7 heads
Mike, I would go through the motor you have now. Do a compression test, check the oil pressure with a mechanical guage, vacuume test, and a possibly a leak down test.
If the 289 in the car is still healthy I would dump the 2 barrel carb, put on an aftermarket intake, get some headers and possibly go over your exhaust.
If you are feeling froggy and the motor checks out. You can also gain power with a new cam, and some aftermarket aluminum heads.
But, just swapping the intake and carb will give you a definant boost in power. Exhaust and headers are supposed to be the best bang for the buck.
The '96-97.5 5.0L Explorers have regular GT40 heads & EGR intake. After that they have GT40Ps with no Thermactor ports, external EGR, a relocated sparkplug, and better exhaust ports. That continued until about 2001 when the pushrod engine was dropped entirely.
