akd67 said:
How about a forum where you can show boobies?A lot of the the boat forums have em!
There's lots of places to see that, we don't need it here. Back to the topic...
crushnut said:
BTW, Isn't that the reason why this sticky was made
http://forums.stangnet.com/showthread.php?t=403856
Okay, you got me there, I didn't even know it existed. I see the FAQ tab, but find out that I have to ask a question (search) to find it. I don't even know how you got to that thread (I didn't try the search function under the FAQ). I think if you want to have a seperate forum, I think it ought to be a FAQ forum that no one can post to, only moderators. If you have a question about a FAQ, you put which FAQ # it is and post it in the regular forum. If it's something not covered, then a moderator will add it to the FAQ forum.
But SD's right, if you can't simply put it back the way it was (restoring, repairing) how the heck do you have the skills to modify it? For example, my boss, a mechanical engineer (doctorate), has a 70's Oldsmobile land barge that he drives. He just put a new battery and a resistor into the car as it wasn't holding a charge in the old battery. It still won't. The alternator has been tested, and it's putting out an acceptable amount of voltage (can't remember the number). The cables test good for resistance and the alternator appears to be charging the battery and the car will still run after the cables are removed from the battery. We have an electrical engineer that is also a gearhead that's looked at it, we still can't figure it out. About the only possibility I can think of is a bad new battery as there is no draw (dome light, etc.) while its setting. There's a fried ground wire from the post to the radiator support that's probably a 8-10 gage wire that's just missing the insulation. We were wondering if it's a fusable link, but it's not burned thru so......
I guess this means I shouldn't modify anything?
(Answer to follow, but postulate your own solutions.)
SD's not saying you need to be a ASE certified mechanic, but you need to be able to diagnose simple problems. There are tons of project cars out there that have been started, but not completed, because of money woes, or they've just gotten in over their heads. As a parent, I often tell my kids the reason we tell them not to do something is not just to spoil their fun, but that maybe we've done it and there are bad cirsumstances that will most likely arise from the outcome.
I agree with GP, you don't put a top fuel motor in a '65 stang and not expect to do some other upgrades.
brtnstrns, have you read the link to the FAQ that crushnut posted above? you say you have plenty of sources that know way more than anyone you've ever met, how do we know whom you've met? I'm not dissing you or your sources. My sources? ASE Ford Mechanic with well over 20 years experience, he also has a 8.40s tube chassis Falcon and has a long experience running SBFs, owns an R-code '69 Mach. ASE Ford Mechanic with 10 years experience, has been drag racing SBFs for 8 years and installs motors, turbos, and superchargers on the side. ASE Mopar Mechanic 15 years experience, former roundy round owner and driver. Race Car Chassis fabricator, former ASE mechanic in an independant garage, building mainly drag cars for over 15 years, lots of 7 second, 10.5" tire'd Mustangs. Through these 4 guys, I've met dozens of others I can get information through, the chassis guy alone has been good for dozens of contacts on his own, I can get info from manufacturers thru him. I also know a guy that restores cars from his house, some of them have had wooden frames, that's how far back his experience goes, another used to restore '57 Chevies, he sold a 'vert for $68,000 at Kruse in Arizona but had about $76k in it (market was down). I know another guy that restores cars, one of which was the first made Shelby Hertz car, not one of the repainted ones. Another is an insurance adjuster and former body shop manager, two others go way back and have direct relationships with Ford corporate and have many old race cars (at last years 100 anniv., Ford had 100 race cars significant to their race history that they wanted at their event, one of these two men had 10 of the cars). Another guy makes parts for street rods that other companies buy from him and sell as their own, he also builds street rods on the side. Two aircraft mechanics, owners of powder coating companies, large well known engine builders, etc.
Answering SD's questions at the end of the first page would help to answer some of the questions of the swap. There was too little info given and the question was vague, we don't know what you know and can't read your mind. Its not a bash. I often try to put myself in the place of the person to whom I'm asking the question to see if I've given enough information. We realize sometimes someone doesn't know what questions to ask, if you take that generalization to assumption, if you don't know what to ask and how much information to give, you're probably not very experienced and may not be able to take on some more complicated projects. Most often though, this is not the case. People just ask a simple question thinking those who answer will know exactly what they're talking about. I guarantee you, we've all done it more than once.
Talk forum, rarely if ever go there myself. A lot of it still spills over into here.
mp67, that is exactly what I consider a restomod as it can still go back to original without any major reconstructive surgery.
I think the forum is great, but I do wish the FAQs were easier to find. I think oboebrian needs to have it permanently installed as a sticky at the top of the regular forum. The only reason Michael Raburn might not want to is that Brian hosts them from his own website and not StangNet's, it ought to be hosted here though, I think that it would help on all the forums.
