Ok, so I have this fuel leek in my car. Its because the hard line was broken and a PO at some point repaired it with rubber hose which of course degrades over time. Guess where the brake is ? Thats right, the drives side frame rail... you know the LOWEST point on the car where the engeneers ran a damn fuel line... that was brilliant.
Anyways, I'm going to be pulling my motor soon (soon is a euphanism) so I figured what the hell, why don't I just replace it with some brand new Stainless Steel line. What I was thinking of doing is running some 3/8" fuel line up underneath the transmission tunnel right next to the 3/16 brake line that is already there. I was actually going to run a pair of lines in there so that if I ever wanted to go EFI (which I provably will eventually) it will be there, ready to go.
What I want to know about the fuel line, are there any safety concerns when it comes to running a fuel line there ? once the trans is bolted down, it isn't going to come up and whack the fuel lines so I'm not worried about that and the diff certainly isn't going to come up and bite into the lines. What I am more specifically worried about is vapor lock. Will the heat from the rear of the engine create any issue with vapor lock in the lines ? I doubt it would. If anything, pre-heating the fuel would most likely improve the combustion because I don't think that the heat from the back of the engine would be hot enough to create vapor lock but that is why I'm asking. Would it be an issue for either a carbed or an EFI engine ?
On to the fuel cell section.
I was thinking of using a universal fuel cell. I am not going to spend God know how much on a fuel safe cell. Summit racing sells some nice aluminum ones and some steel ones as well. I don't really know much about fuel cells. I did a search and turned up some ways to mount them. It does not seem to be very difficult to get one to fit in the stock hole as long as they are the right dimensions.
What I am interested in as far as fuel cells go is, should I get a cell with a bladder and if so what kind of bladder ? Something else that interests me is an in tank pump. Can I just use something like a late model fuel pump ? If I switch over to an electric pump I don't want to hear the bastard and an in tank pump is more reliable. If I do eventually go EFI then I will have to go with an electric pump so I figure if I am seting this all up now I might want to switch now and use a fuel pressure regulator to take care of the extra PSI from the pump. And of course, if I were to put an electric pump in I'd make sure to use an inertia switch ;-)
Sorry for the long post but details are a must IMO.
