you have a few options. you can use the autometers in place of stock gauges. just screw the oil pressure sending unit into the log that comes off the engine by the oil filter. and just use some adapter form lowes/hope depot to make the coolant temp gauge work in the stock port on the intake. thats what i did. or you can use some fittings on the oil pressure side, to use both the dash gauge, and the autometer. for the coolant temp, you can use the alternate insert on the back corner of the intake, this one will give a less accurate reading, so i would use it for the dash gauge, and use the front port for the autometer.
