new guy here
  • Thread starter Thread starter 302mustang68
  • Start date Start date Dec 2, 2008
302mustang68
  • Dec 2, 2008
hey guys just wanted to say hi I just recently joined you have alot of valuable infomation here on this forum.. I have a 1968 mustang coupe that im currently building the motor for which is a 1987 carburated 302 with E303 cam bbk headers forged crank and pistons msd distributer paxton novi 1000 supercharger.... my question is does anyone have a 302 with a E303 cam? what size pushrods did you go with? what brand? and what about rollerrockers?
thanks ill try and get pictures as soon as I can the mustang is currently in the shop being sprayed
FastDriver
I was uncomfortably high & wearing a helmet
SN Certified Technician
Sep 5, 2001
6,238
2,942
224
Vass, NC
Dec 2, 2008
  • Dec 2, 2008
Welcome to the board, 302mustang68. It sounds like you have a nice one. I'm sure one of the guys here will help you with the pushrod pushrod length. I've got to say that I have had pretty good luck with TFS pushrods, and FMS B351 1.6:1, and Crane's Gold series 1.6:1 ratio RRs in the past. Given the somewhat low lift numbers for the E303 cam, you might consider 1.7:1 RRs. Be sure to check PTV clearance, though you shouldn't have an issue, and make sure you have a good set of springs.
Chris
Brian@PAR
86
Phoenix AZ
Dec 2, 2008
  • Dec 2, 2008
The answer to the pushrod length is you have to measure. Don't take anyone's word for it. Buy a checker and measure for yourself.
I like the COMP Gold rockers and, as FastDriver says, 1.7's would not be a bad idea.
Comp or TFS pushrods are a good choice as well.
I would also recommend making sure your springs are up to the task of the new cam. If you have stock heads that gets a bit tricky as the spring choices are limited due to the low IH. Be advised that springs wear out and the stock springs are only good for a stock cam. You have to make sure you don't coil bind and just as important you need to make sure the spring pressures are right.
Last E cam I installed it cost over $250 in springs and hardware. Now this was a different application than yours so you probabaly won't need as much spring but you still need to make sure you use what is recommended.
Crank no start on a turbo and cammed pushrod 5.0
  • 1630stri
  • Sep 2, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Sep 16, 2026
Qtrhrse23
Fox Another try for the European guy to get his first Fox
  • Schargedfox
  • Aug 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 4, 2026
DadLife0724
Z
Progress Thread zeth194 - New Guy on the Block
  • zeth194
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Apr 26, 2026
LILCBRA
New Here, but not new
  • Bronco2fan
  • Apr 10, 2025
  • The Welcome Wagon
The Welcome Wagon Apr 10, 2025
Bronco2fan
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
