new guy here
302mustang68
hey guys just wanted to say hi I just recently joined you have alot of valuable infomation here on this forum.. I have a 1968 mustang coupe that im currently building the motor for which is a 1987 carburated 302 with E303 cam bbk headers forged crank and pistons msd distributer paxton novi 1000 supercharger.... my question is does anyone have a 302 with a E303 cam? what size pushrods did you go with? what brand? and what about rollerrockers?
thanks ill try and get pictures as soon as I can the mustang is currently in the shop being sprayed :D
Welcome to the board, 302mustang68. It sounds like you have a nice one. I'm sure one of the guys here will help you with the pushrod pushrod length. I've got to say that I have had pretty good luck with TFS pushrods, and FMS B351 1.6:1, and Crane's Gold series 1.6:1 ratio RRs in the past. Given the somewhat low lift numbers for the E303 cam, you might consider 1.7:1 RRs. Be sure to check PTV clearance, though you shouldn't have an issue, and make sure you have a good set of springs.
Chris
The answer to the pushrod length is you have to measure. Don't take anyone's word for it. Buy a checker and measure for yourself.
I like the COMP Gold rockers and, as FastDriver says, 1.7's would not be a bad idea.
Comp or TFS pushrods are a good choice as well.
I would also recommend making sure your springs are up to the task of the new cam. If you have stock heads that gets a bit tricky as the spring choices are limited due to the low IH. Be advised that springs wear out and the stock springs are only good for a stock cam. You have to make sure you don't coil bind and just as important you need to make sure the spring pressures are right.
Last E cam I installed it cost over $250 in springs and hardware. Now this was a different application than yours so you probabaly won't need as much spring but you still need to make sure you use what is recommended.
