  • SN95 4.6L Mustang Tech
new guy + i need help...
  • Thread starter Thread starter Pughman
  • Start date Start date Dec 25, 2004
Pughman
295
in a galaxy far far away"MISSOURI"
Dec 25, 2004
  • Dec 25, 2004
I have this "roaring" noise in the rear end of my 1998 mustang gt.Any suggestions? bearings? axles? gears? i got the car with 109,000 mil. on it and it is a 5speed, with the 4.6, and 8.8 rear . i payed 5000.00$ CASH FOR IT WITH THE "ROARING" noise ....... it booked for 9000.00 ? did i get riped ?
GTsleeper
179
St.Louis, Missouri
Dec 25, 2004
  • Dec 25, 2004
Find out if the person before you changed the gears in the car. Could be the individual who installed the gears did it wrong.
Pughman
295
Dec 25, 2004
  • Dec 25, 2004
GTsleeper said:
Find out if the person before you changed the gears in the car. .
no way to do that was got off a lot ... any one do a rebuild on there 8.8 rear end ? and what the cost was to have it done ?
D
Darkhorse845
Banned
Nov 17, 2004
101
Las Vegas,Nevada
Dec 26, 2004
  • Dec 26, 2004
Welcome to Stangnet!
T
tuned
23
  • Dec 26, 2004
i have a 1998 mustang gt auto with around 70k miles. my car is currently in the shop with the entire rear end being replaced. it was shot. but be sure thats what the sound is from, sounds run. i'd suggest getting up to about 45 on a isolated street, putting the car in neutral, and turning off the engine. this way you wont here the exhaust and engine... now slightly swerve back and fourth, and if you hear the sound change in the rear end to a bit higher pitched sound its probably your axle barrings, and if thats what it is you should take it to a shop and get it looked at, because it will wear out other parts in the rear end.
personally since i has to change the rear end altogether (800 bucks + 400 install) I got 3.73 gears.
good luck. hopefully its just the ring and pinion.
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
F
Ford 460 swap
  • Ford460
  • Sep 13, 2026
Ford460
F
new :poo: box, may need to hit you guys up for 79-82 info when i fix thIs turd.
  • rednotch
  • Sep 27, 2025
  • 2 3
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 23, 2026
limp
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
Eight inches is enough for me...
  • 351MooseStang
  • Nov 27, 2025
1974 - 1978 Mustang II Talk & Tech Mar 2, 2026
Bullitt347
