I have a 93 mustang gt with a vortech supercharger with alot of mods, 36lb injectors, 255 wal boro fuel pump, Gt-40 heads and stock cam, eagle rolling assembly for bottom end, The advice I'm looking for today what heads and cam would be a good application for this set up I have. I've been looking at the AFR or the trick flow heads. And as for the cam I've heard that I don't need an agressive cam cause I would loose some boost from my supercharger, is that true? I would appreciate any advice if you need more info just let me know.
) though, as the valve reliefs in your pistons may have your hands tied on which heads you can run.
