new guy with big problems
  • Thread starter Thread starter frankenstein gt
  • Start date Start date Apr 3, 2010
F
frankenstein gt
9
lakeland FL
Apr 3, 2010
  • Apr 3, 2010
i bought an 87 gt air density t top car that uses deep reach plugs? i then bought an 88 gt that was in much better shape with no motor or trans for 400 so this 88 was a maf car i put my motor and ecu in this car the car runs rich surges at idle sputters if you give it more then 1/4 throttle and dies after you give it gas i have replaced the tfi,coolant temp,coil,fuel filter,tps,plugs,idle speed control valve and still runs like complete **** pls forgive my type and grammer i am in the dark
SScott
Powered by LORD
Apr 23, 2004
304
Alabama
Apr 3, 2010
  • Apr 3, 2010
Not positive but I wonder how good the fuel pump is since it was a roller. Maybe check your fuel psi?
F
frankenstein gt
9
lakeland FL
Apr 3, 2010
  • Apr 3, 2010
The guys I bought the car from put a new pump in it to get it running. Then used the motor for a blower car. So as far ass I know the pump is new. but i have not checked the fuel pressure. and dont have the tools to do so.
F
frankenstein gt
9
lakeland FL
Apr 3, 2010
  • Apr 3, 2010
37 veiws and one reply nice.
HISSIN50
34
129
Apr 3, 2010
  • Apr 3, 2010
Have you pulled codes?
What mods are done to the car?
F
frankenstein gt
9
lakeland FL
Apr 3, 2010
  • Apr 3, 2010
msd coil,shorty headers,full 3in to flowmasters with a turndown,k&n filter on stock intake,e fan Thats about it.
I cant pull codes all i have is a testlight and jumper wire and nothing happened
what is the sensor on the driver side next to the first injector looks like a large temp sensor?
HISSIN50
34
129
Apr 3, 2010
  • Apr 3, 2010
You need to figure out why you cannot pull codes. That's the place to start.
If the sensor you're talking about is to the driver's side of the dizzy and has one wire on it, it's the temp sender for your gauge.
F
frankenstein gt
9
lakeland FL
Apr 3, 2010
  • Apr 3, 2010
ok then its the dizzy. i just converted it to mas air and got another mass air ecu.
F
frankenstein gt
9
lakeland FL
Apr 3, 2010
  • Apr 3, 2010
that did nothing same problem
F
frankenstein gt
9
lakeland FL
Apr 11, 2010
#10
  • Apr 11, 2010
  • #10
what about a bad fpr
stykthyn
5,232
2,652
223
gainesville
Apr 12, 2010
#11
  • Apr 12, 2010
  • #11
all the plug wires in the right area? where is timing set? have you figured out why you cant pull codes? have you gone through the surging idle checklist? It helped me a great deal when I was trying to fix my car.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Apr 12, 2010
#12
  • Apr 12, 2010
  • #12
SD system? Check the readings of the MAP sensor. It could be a bad O2 or exhaust leak as well but I really doubt it. Definatly check the MAP
TenorPlayinGuy
1,208
Canyon Country, Ca
Apr 12, 2010
#13
  • Apr 12, 2010
  • #13
Sounds like you put the SD Computer into a Mass air car. I don't think that works.....
I know you got another ECU, but what was the code? Ideally you'll want an A9L code. There are others that work.
Engine Rough idle and aggressive sputtering when accelerating
  • 88vertible
  • Aug 13, 2025
Fox 5.0 Mustang Tech Dec 13, 2025
Jarhead67
J
Running very very rich
  • 2esoteric
  • Oct 31, 2025
Fox 5.0 Mustang Tech Oct 31, 2025
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
