New here..need help after gt40p head swap WHAT SHOULD MY FUEL PRESSURE BE?
marksgirl98
1993 ford mustang solid 302, gt40p heads rebuilt, explorer upper and lower intake, new plugs and wires autolite 104s gapped at .50, cold air intake with the air charge sensor relocated to it, new iac, new tfi module, checked all grounds they're good, 70mm throttle body with 70mm egr spacer, bbk shorty heads, bbk off road h, mac pro dumps, 5 speed, rebuilt rear with 390gears
*still has stock 19lb injectors,
**getting tired of nickel and diming myself with guessing the solution
THE PROBLEM: the car falls on its ass at 5000rpms after taking forreevvver to get there....it chokes itself up like its not getting enough fuel...i know its running lean the plugs were white when i changed them yesterday...
it seems there is no bottom end or torque no quick throttle response
WHY!!??
???****could it be my fuel pressure isn't high enough...its set at 30psi right now...timing is at 13 degrees ????
thanks guys
Fuel Pressure with the vacuum line to the regulator off should be 39-40 psi. With the vacuum line attached I normally see around 34-35psi on the gauge. And thats typically with a cam that pulls 17-18" of vacuum.
I had a problem kind of like that. The car would drive normal but at WOT at the track, it would fall on its face at the top end. after checking my data logs, I found that the computer was comanding it to run rich but I had 90+% injector duty cycle and the wide band was reading way lean. All my ignition parts were new at that time so I suspected a fuel issue. I did a pressure test and it said near 40 psi. I read somewhere that you should pump so much volume in so much time. Sorry I dont remember the numbers. I did try to let the pump fill a coke bottle with the pressure tester hooked up and it didnt fill it enough. I dropped the tank to find the pump screen had a hole in it & my pump inlet was half plugged with trash. Put the 225 walbro in, turned up my pressure & then I was running in the 60% range at WOT.
After I did my gt40p swap I had some issues also. My plugs were arcing through or around the spark plug boot.. The car would rev fine sitting still, but under load it ran like crap.. I think because the spark plugs were firing when they weren't suppossed to. So I popped the hood in the dark and got down in the engine bay to look for arcing..#4 and I think #7 were the problem.. It seemed like it would only do it once the engine warmed up. I put the accel shorty plugs in, new wires and the high temp boot covers on.. Now it runs great.
Dumping the computer diagnostic codes on 86-95 Mustangs
Revised 19-May-2009 to update drawing for dumping the codes on 86-88 Mustangs with no check engine light.
Here's the way to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
Be sure to turn off the A/C, and put the transmission in neutral when dumping the codes. Fail to do this and you will generate a code 67 and not be able to dump the Engine Running codes.
Dumping the Engine Running codes: The procedure is the same, you start the engine with the test jumper in place. Be sure the A/C is off and the transmission is in neutral. You'll get an 11, then a 4 and the engine will speed up to do the EGR test. After the engine speed decreases back to idle, it will dump the engine running codes.
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
attachment.php
attachment.php
What to expect:
You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
Alternate methods:
For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
Or for a nicer scanner see Equus - Digital Ford Code Reader (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
Or for a nicer scanner see http://www.midwayautosupply.com/p-7208-equus-digital-ford-code-reader-3145.aspx– It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
