New intake, what should it run?
90_Red_LX
668
Asheboro, NC
I added a edelbrock rpm intake to go with a 65mm tb/egr spacer and 70mm maf sensor along with the mods in my sig and ran a 14.0 @ 98 mph with a 2.1 60'. However I set the timing with the spout in the connector, so the the next day when I checked it and realized I forgot to pull it out, base timing was below 0 degrees. What do you guys think it'll run with the timing back to 14? I cut 1.9-2.0 60' times before the intake, and was cutting 2.0's with the intake and screwed up timing.
I was hoping for a 13*** and I'm coming close. With the timing actually set right it should click 13's off on every decent run I hope. I should actually be grateful I wasn't picking up engine parts at the end of the track though. As far as it was off I bet it wouldn't run like that a whole lot longer without giving out.
