New K-member and alignment probs...
90muustanggt
1,922
Northern VA
Well I finished the engine, everything runs well. I also installed the Hal K-member. I work at a tire shop so i tried to align it the other day. As usual after a suspension install the toe and camber were out and adjusted fine. However, i could not for the life of me get the caster in line.
Any suggestions? Tips? WIll this effect my handling?
Had the same problem. You either need caster camber plate or you need to elongate the K member mounting bolt holes and push the K member foreward. If you don't it'll handle poorly and be really twitchy and want to follow grooves in the road. Been there, done that.
Jamie
Ranchero has it dead on. I did the lowering springs, and had to get cc plates to get the alignment. You could try elongating the holes first, or just go for the plates. If you have a shop available, you could probably estimate the amount you need to move, pull the bolts, grind the holes, an re install it and be right there.
I have the CC plates, i guess im gonna loosten the k-member bolts and push it all the way forward and try to realign it. What i did the first time was to measure the front to back and across measurements for the k-member to get it aligned. Should i just forget that and push the k-member forward?
