Yes.2bav8 said:Cal-Tracs![]()
302 coupe said:i went to the track for the first time today with my cal tracs...had some wheel hop but I was able to tune it out with about a full turn of preload. Also, cut a 2.03 60 ft (previous best was 2.27) on 225/60/15 radials, LOL..... I don't think I could have done it without the cal-tracs.
mustangman70 said:I have the lakewood traction bars and LOVE em![]()
302 coupe said:note that the lakewood slapper bars serve only to reduce axle wrap. That is why they are $30 and the cal tracs are $320. Don't fool yourself into thinking that a slapper bar will work as well as the CT's.
mustangman70, definately post back and tell us how your car hooked up.
10secgoal said:Tell you what. I need a set. I have a home made set now that works, but want the real thing. I built mine for the same reason you are doubting it now. Now that I know it works, I am going to buy some. If they don't work out, I'll buy them from you, for a little more than 200 bucks though.
thehueypilot said:That's the story of my life.......I pay full price for everything and turn around and sell it for a loss to everyone else! LOL Another concern is the solid, spring eye bushing. I drive mine on the street so a solid connection like that would transmit vibration directly into the frame. I replaced TCP solid motor mounts not too long ago for that same reason.
thehueypilot said:I believe he is talking about engine anti-torque straps. After removing the solid TCP engine mounts I modified my stock mounts to include a grade eight bolt that runs through both sides of the engine mount to restrict engine movement to about 1/4". This gives me no vibration through the frame because of the rubber mounts yet keeps the engine from twisting/tearing out of its mounts.
10secgoal said:I do need to do that too. But I mean strapping the suspension to limit travel, to try and keep the nose on the ground. I made a change and they only poped up off the bottle. But I think after this next mod is done, if traction is there, I may find I have another problem.
thehueypilot said:I didn't realize that switching from a vac sec carb to a DP carb would effect the launch as much as it does. It took a couple of tenths off my 60' time and put that much more stress on the suspension. So far I don't need to limit the front end travel yet......
