New motor...rocker question
ninety15.0
1,336
Well i've got about 750 miles and one oil change on my new motor...specs are in my sig. So everything is good so far and the car feels real strong...but i have a fairly noticable tick. Its mostly at low rpm....or just off idle. I have heard that a little ticking is fairly normal with roller rockers but im not sure how much ticking is too much. No other problems with the car, any help would be appreciated. thanks :flag:
Nick
im in the same boat as you man, i put cast-iron gt-40's n my car with crane 1:6 rockers, and they ticked like a mutha fucc@! so i just have my conventional ones on for now and they still make noise, just not head jarring
as for you, well i wouldn't be too worried aout it if i were you, if they're not makin too much noise, and it's just at idle and low r's, that sounds like it would be normal...
yea its not a really loud noise. it actually gets a little quieter once the car really warms up, but when its cold and idling i can hear it over the exhaust. thanks for the reply...anyone else?
with the CC magnums, they should be slightly louder than your fuel injectors...not even really a tick...more like a cycling...I know it took a while for a friend of mines car to quiet down, but, honestly, they shouldn't make much noise at all. roller rockers as a general rule make a little more, but should never be so bad that it's louder than the exhaust.
Am i doing any damage by drivin it around until the weekend when i have some time to rip the covers off and adjust em? like i said its not crazy loud but def noticable. thanks for the responses guys! cheers
Eh if its not real loud dont worry.I just put on a set of Crane rockers (replacing my Scropions,whitch were adjusted and ticked),and they tick,go figuer.But I change cause the cranes are better made rockers.
...worst case scenario, if you put several thousand miles on it (prob'ly won't happen soon)you could disfigure the valvestem tips...(yeah right) or maybe collapse the lifter (more likely than the valve bit, but still not likely)
more than anything it'll just be annoying...
